Re-using LNB from Sky minidish | |
| Member Join Date: 29-06-2008 Location: West Midlands
My System: Sky |
I currently have a sky dish with a quad LNB feeding a sky + box plus an extra box. If I were to purchase an motorised 80cm dish would I be able to re- use the lnb and use the spare feed to connect to a Technomate TM-5300 D+? I want to still use Sky could I set the Technomate back to the Sky Satellite when I wanted to watch Sky through the Sky + box? | ||
| Specialist Contributor Join Date: 05-04-2005 Location: Midlands UK
My System: Skymaster DCI9900 + PC/twinhan combination. 80cm dish. GBPVR with 2 DTTV cards +hauppauge Media MVP | Well you could but it wouldn't give optimum results because the sky dish is 'short and wide' while a standard dish is 'tall and thin' and the LNB is matched to the appropriate profile. Also the method of mounting is often different. You could probably get away with it for Sky because an 80cm dish has a greater area and so you'd still have a strong signal despite the mismatch, but you may suffer on less strong satellites. You are allowed 2 dishes under planning regs, so you could leave your Sky dish where it is and still have a motorised one on the other receiver | ||
| The Following User Says Thank You to pgh13 For This Useful Post: | Neilpet (21-07-2008) |
| | #4 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | The rules have changed, see the planning guidelines sticky at the top of this section. This page also refers to the guidelines
__________________ | |||
| The Following User Says Thank You to rolfw For This Useful Post: | Neilpet (21-07-2008) |
| | #5 | ||
My System: Technomate TM6800D & TM1000D+ receivers, Stab H-H90 motorised Triax 1m dish 42E to 30W. Fixed Orbital 1m on 26E, 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | You are best off, leaving the Sky receiver on a fixed dish anyway, moving the dish around will only cause problems with the Sky box.
