Any Combined C/Ku feedhorn for Offset? | |
| Member Join Date: 22-07-2008 Location: Singapore
My System: 1.8 metre offset |
Hi, I am currently looking for a Combined C and Ku band Feedhorn meant for offset dish (f/D=0.6). However, this seems very rare. I would need one that is motorised/servo. Please advise. Thanks. | ||
| Regular Member Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 Dual Axsis Echostar Dvr 7000 Monterey 140 Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesch for cband! | the combinatation c/kuband in one lnb,over 14/18 voltage swichting,has very bad performance in kuband! you cant change anything,the postion angle of the lnb is complitly fixed! cband singal is okay! | ||
| Member Join Date: 22-05-2003
| Have you used a BSC621-2 ? They work very well on a corrently set-up large prime focus dish ! | ||
| | #5 | ||
My System: 1.8 metre offset | Well, that's why I am looking for a feedhorn with separate LNB. I am looking at a feedhorn with servo, such that I can adjust the skew over the whole horizon. Thanks. | ||
| | #6 | |||
My System: 1.8 metre offset | Looks like I need to give up the idea of a Offset dish, and go for a 2.4m mesh prime dish instead...sighzz Also, I do not trust those make-shift rings/cornical that modify the f/D of a feedhorn that is not from the feedhorn manufacturer themselve, or does not come with proper documentation, engineering drawing etc. I do not want to trial and error, as there is no current (other) solution for Offset dish. | |||
| | #7 | ||
| Member Join Date: 03-08-2008 Location: Mauritania, West Africa
My System: technosat 7000 IR PLUS Starsat 4200 D Super Starsat 1500 D Ultra 1 moving antenna 1.80m 1 moving antenna 2.40m | Hi,cl7teckie! I don't speak english very well but I've underestood your "probem". It's very easy to resolve it: At first, u have to install your Ku-band(0.2dB, 60-70 dB gain) on your antenna and try to track all Ku-band satellites (the most important are : the most eastern one,the central one -above your head- and the most western one. Try to have the maximal signal strengh on all Ku-Satellites by adjusting the Df and the Ku-band polarity. After that let your antenna go to most eastern satellite and look to your signal strengh and try to fix your other band( Single C-band 17°K like Diplosat) above or under the Ku-band (universal one) using rubber(scotch in French). Your two bands must look at the same dot: the center of antenna. Note: before fixing your second band, U have to imagine a line dividing your antenna in two equal parts. This line must be perpendicular to rotation axis of your antenna and the C-band must look to a dot on this line (above or under the antenna center (this dot must be very near of the focal point of antenna. The two bands can approximatively the same Df (=focal distance). Don't forget to adjust the C-band polarity by turning it left or right ad when U get the best C-signal on C-satellites U have to attach(fix) the two bands very well using black electrical rubber BUT be careful : don't move Ku-band when fixing C-band | ||
