Confused about LNB skew | |
| Member Join Date: 09-07-2008 Location: South Yorkshire
My System: Sky +, Passion+ HD, Various Mac's, too many gadgets to count. |
After 3 2 hours sessions trying to line up my dish I finally have success what took so long was me twisting the lnb the wrong way! I knew that I needed to twist it about 12 degrees but was twisting it the wrong way![]() Why would my lnb be twisted in the opposite direction to all my neighbors ? they all have sky dishes, would it make a difference ? | ||
| aka Skyman Join Date: 13-06-2003 Location: Limassol, Sunny Cyprus
My System: 3m(sky),1.8m(astr/hotbird),1m (nilesat)1m(arabsat)diseqc 4,sky plus,visionet 8000s. Satlook nit colour + Horizon hdsm. wii ![]() | Doesn't make sense. Maybe your dish is back to front
__________________ | ||
| | #3 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | It isn't a Fortecstar FCKUVN LNB by any chance is it? http://www.satellites.co.uk/satellit...cstar-lnb.html
__________________ | |||
My System: 3m(sky),1.8m(astr/hotbird),1m (nilesat)1m(arabsat)diseqc 4,sky plus,visionet 8000s. Satlook nit colour + Horizon hdsm. wii ![]() | Is that an anagram or a limited edition french connection lnb ? ![]()
| | #5 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Yes, does rather lead to that thought. ![]()
| | #6 | ||
My System: Sky +, Passion+ HD, Various Mac's, too many gadgets to count. | | ||
| | #7 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | The skew is about 45 degrees off, see my linked thread above.
| | #8 | ||
| Information Exec Join Date: 07-05-2007 Location: Midlands (UK) & Lanzarote (Canary Islands)
My System: 43cm Dish, Sky Plus, FRACARRO PENTA 85, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W | Must be so confusing without the meter to confirm. Bit like the MTI supreme LNb but that's the other way ![]() That was a good find Rolf ![]() | ||
| | #11 | ||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
It means that when used on a motorised system when setting lnb completely vertical for your due south satellite you will have to set it at the angle shown, that is all but because it does not follow existing conventions it just makes what can be to some a difficult procedure harder still.
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | ||
| | #12 | |||
| | #13 | |||
Rolf was setting that up for a fixed installation on 28.2 East and the expected lnb skew was shown in RED whereas the cable exiting is at almost 90 degrees to that which implies that setting the lnb up for a motorised system you would have to set the cable output to about 15 minutes past the hour to be correct but never having had one seen one I can only work with the information supplied. In my opinion get a different lnb for £10.00 you have lost nothing
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | |||
| | #14 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Set it at between 4 and 5 O'Clock and that should be roughly correct for zero skew, but will need fine tuning. As Topper says, buy another LNB, something like the Inverto, probably won't cost you more than a tenner. ![]() You also need to phone Maplin and let them know about the problem, as unless people do, they won't know that they are selling a defective product.
| The Following User Says Thank You to rolfw For This Useful Post: | DeanoDave (3 Weeks Ago) |
