wall Mount
Thread Tools Display Modes
Old 27-07-2008   #1
My System: technomate 6900 hd darkbox rev 2007 104cm gibertini dish. moteck 2100a with diseqc 12
wall Mount
what size bolts do i need to bolt it to the wall and what sort
den123 is offline   Reply With Quote
Old 27-07-2008   #2
wod
My System: 90cm channel master dish @1west, vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish
well i used 8cm long 10mm sleeve anchor bolt from b&q which has held mine up for over a year now without any problem
Old 27-07-2008   #3
Rd100
Posts: n/a
Hold what to the wall hanging basket, basketball ring, hose pipe holder, gate ??????
Old 27-07-2008   #4
Information Exec
satelliteman's Avatar
Location: South Midlands, UK & Lanzarote, Canary Islands, Spain
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N
Assume your referring to your 1M dish & Moteck Motor.
Use a pair of T&K brackets and M8 / 60mm anchor bolts will be fine (drill size 14mm). You can use M10's also but be prepared to drill several 16mm holes
SM
__________________
A Detailed DiSEqC Motor Installation Set Up Guide HERE
Motor Installation 'Quick' Reference Guide also HERE
Old 27-07-2008   #5
thanks to you all will do that
[IMG] code is Off
Forum Jump
