Twin C- band LNB
Old 29-07-2008   #1
patmos's Avatar
My System: 1.2 m Eurostar dish KU band W3A, 3.1 M mesh C band on the arc from Atlantic bird3 to Measat 3, 1.5 m offset on PAS 10 KU, 70cm Offset on Eutelsat W2, 2.4m prime (Dual LNB) on PAS 7/10 @ 68 Deg E and Thaicom @ 78 Deg E STARTRACK NC707 Plus, Skyst
Twin C- band LNB
Please help me find a twin c-band LNB. I enquired with one shop in the US. Sorry they do not ship to Mauritius. any place in Europe or Asia?
patmos is online now   Reply With Quote
Old 29-07-2008   #2
Turok's Avatar
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband!
hello!
look on the site **w.inverto.tv,they have a cband twin lnb in there program!,with very good quality!
i have an old call amp twin with 25 Kelvin
if you want to buy in asia,you get it also on the website of the thailand company!
**tp://www.infosat.com/
Turok is offline   Reply With Quote
Old 31-07-2008   #3
patmos's Avatar
Thank you.
Old 23-11-2008   #4
My System: Dreambox 7000 + 1m20 motorized
Hi Patmos,
the shipping from U.S shop will be to expensive.
the best solution is compagny in your area like thailand.
try _www.infosats.com
price and shipping to mauritius is close to 4 to 5 time less expensive than U.S.
i think i know you, are you working for MT? did you cover your big mesh dish by metal plate?
zorrin is offline   Reply With Quote
Old 24-11-2008   #5
Turok's Avatar
Hello!
the inverto twin lnb,has the best perfromance!
,yes shiping in thailand,is very cheap,a small parcel,or letter,with registred mail,is cheaper,then sending,the same letter inside,any eu country
shiping to mauritius from europe is around 30€,when its have over 10 kg,then its very expensice!
can someone from maurizius post picutures ,of your dishes,would be intresting,for all members thx!
Old 25-11-2008   #6
patmos's Avatar
Thank you guys. Someone promise to bring one for me from China. Otherwise I have to order. Just want it for my DVB card.
Zorrin happy to hear you're from Mauritius. I'm in Terre Rouge and by the way I cannot hide my dishes.
Old 25-11-2008   #7
patmos's Avatar
pics of my set up
Though not the correct section. here are some pics of my set up under the tropical sun.
Twin C- band LNB-d1-jpg   Twin C- band LNB-d2-jpg   Twin C- band LNB-d3-jpg   Twin C- band LNB-d4-jpg
Old 01-12-2008   #8
Et bien oui, je suis Gerald de Grand Bay.
Merci encore pour l’invitation, mais le boulo m’empêche de passer te voir.
Je vois que tu as de plus en plus d’antennes !!!
As-tu pu remettre en état l’antenne de 2m50 ou 3m en résine ?
a bientôt
Old 02-12-2008   #9
patmos's Avatar
Yes the fibreglass is 3m 40 in diameter( The dish hiding behind the Elsat in the photo). It is now on Intelsat 906 at 64 deg. But It performs less than a 2m40. I spent much time in tuning it. Sans succes. I'll bring it down.
Gerald tu peux passer quand tu veux. Anything with your motorised 120cm and dreambox? Mail me if you have time.
Old 02-12-2008   #10
Turok's Avatar
do you have oftenstrong winds in mauritius?
could it be a dangeour for your dish?
Old 03-12-2008   #11
patmos's Avatar
We are in cyclonic season now. Gusts may be of the order of 200 KM/Hr. That's why I want to bring down the fibreglass. The 120/150 cm can be easily brought down before cyclones. The big 3m 80 I will secure with guys. The metals sheets will definitely go away. The 2m40 is a transportable one.
band, lnb, twin
[IMG] code is Off
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. Uptime monitoring by PageUtils.com
