diseqc switch
Thread Tools Display Modes
Old 20-08-2008   #1
My System: technomate 1500, 80cm dish , fixed monoblock, astra and hotbird
diseqc switch
hi,i have a question about a diseqc switch, is it possible to use it with a monoblock (hotbird astra) and also freesat? if i can? how do i do it?
scouse645 is offline   Reply With Quote
Old 21-08-2008   #2
jphili's Avatar
My System: Twin monoblock and twin LNB on 80cm transparant dish rigged for twin reception + TopField TF 7700 HDPVR + TwinHan VisionDTV
You can, and it's been discussed already a couple of times.
Basically you need to connect your monoblock to both the A and B input of your disecq switch.
If you need more info, I guess a quick search could already clear up the fog some more
jphili is offline   Reply With Quote
Old 21-08-2008   #3
Robbo's Avatar
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m +Moteck motor.45E to 45W. 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox.
Yes, apparently you have to solder a wire between the first two inputs, or use a splitter.
Old 21-08-2008   #4
Information Exec
satelliteman's Avatar
Location: South Midlands, UK & Lanzarote, Canary Islands, Spain
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N
They need to make a link connector for this, might be of some use with this configuration.
__________________
A Detailed DiSEqC Motor Installation Set Up Guide HERE
Motor Installation 'Quick' Reference Guide also HERE
Old 21-08-2008   #5
My System: DB7000S HDD USB2GB; FTE MAX S102; 2CM120+ 2Norsat7706A on 7°W; Triax 2X110, 1X88 and 1X64. LNBFs: 2BESTQ, 2InvacomQ; 3XAlps, 2Inverto(1Q), 3XBEST; Switches and M/S; Centauri P-168. 30w, 8w, 5w , 1w, 5e, 9e, 16e, 23e, 28e; 13E, 19E; 26E
Actually there exists a Y connector for this.
I have a few in my parts box
canofan is offline   Reply With Quote
Old 13-10-2008   #6
My System: Humax 8100 2CI Receiver with Astra/Hotbird Monoblok and Atlantic Bird and Hispasat dishes
DiSEQc Switch won't work properly with Monoblok
I have a Lemon 0.2dB Monoblok on Hotbird and Astra 1 and, based on the above advice, bought a WizTech 4-way DiSEQc switch.
I bought an F socket T-piece and connected the centre leg to the LNB1 input and a short cable to then link one of the side connections to the LNB 2 input. The Receiver input was connected to the other side connection of the T-connector. In other words, this was in effect a Y-connector.
Some of the Hotbird channel now don't work, some of them do. Some of the Astra 1 channels don't work, some of them do. I can select all Atlantic Bird and Hispasat channels.
Any ideas folks ?
Peter
Adcham is offline   Reply With Quote
Old 14-10-2008   #7
Robbo's Avatar
Theory only, as I have never done it but:
You have it connected wrong. If a T-piece were to work (I don't know if it does), then:-
You connect T-piece centre Leg to the monoblock.
T-piece side leg to Diseqc switch input 1.
T-piece other side leg to Diseqc switch input 2.
The receiver goes to the OUTPUT of the Diseqc switch.
Any extra LNBS you want go to inputs 3 and 4 on the Diseqc switch.
Robbo
The Following User Says Thank You to Robbo For This Useful Post:
Adcham (15-10-2008)
[IMG] code is Off
Forum Jump
