No or BAD Signal...
Thread Tools Display Modes
Old 23-08-2008   #1
My System: Technomate 5400 CI + USB, INVERTO Silver Tech Universal Twin LNB 0.2, LIDL satellite dish
No or BAD Signal...
Set up dish and LNB , hooked it up to my box but on my box it says 'No or Bad signal'
At the bottom it says 23%....does this mean it is semi hooked up alright ?
Hopefully......
Im trying to get Astra 28E
I think im pointing it in the right direction.......What can i do now ?
Thanks guys..
ash213 is offline   Reply With Quote
The Following User Says Thank You to ash213 For This Useful Post:
kannanni (23-08-2008)
Old 23-08-2008   #2
Information Exec
satelliteman's Avatar
Location: South Midlands, UK & Lanzarote, Canary Islands, Spain
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N
Morning, somehow, I've been waiting for this thread, lol.....
Take these easy steps and it will work.
> Get yourself a compass
> Point the dish to a rough 143°
> Set the dish elevation to a rough 24º although this may not be accurate on the bracket
> Stand in front the dish looking at it and turn the LNb a fraction so the F connector is at a 7'0Clock position.
> Use and in-line meter and move the dish in small movements until it peaks
> OR use the receiver to align the dish by signal screen ( use Tp 10.714h)
> If you find a signal on the meter, scan this Tp 10.714h, 22000, 5/6 (Channel 4)
> If you scan this transponder and get the above.... your on 28E.
SM
__________________
A Detailed DiSEqC Motor Installation Set Up Guide HERE
Motor Installation 'Quick' Reference Guide also HERE
Old 23-08-2008   #3
SM
Sorry what does this mean ?
In addition.....Im currently looking at my satellite set up page..on level its going up and down like crazy from around 30% to 100% constantly and the quality is around 23%.
Do i have to change any of the settings on the satellite set up page like LNQ frequency or type ?etccc
Old 23-08-2008   #4
Information Exec
what receiver you got?
__________________
Old 23-08-2008   #5
technomate 5400 ci+ usb
Old 23-08-2008   #6
Information Exec
Get your self a long extension lead, and take a portable TV out to the garden.
Go to > Installations > satellite set up > Select 28e / Astra 2> Go down and select Tp 10.714h on the receiver.
When you move the dish, you can see the signal / quality levels go up.
When the levels go up, press RED
Tighten up when happy.
__________________
Old 23-08-2008   #7
OK i'll do this.
When you say move the dish, do you mean move the degree's of what its on at the mo ?
Old 23-08-2008   #8
Amo Amas Amant Admin
Topper's Avatar
No
Originally Posted by ash213 View Post
OK i'll do this.
He means rotational adjustment and or the angle the dish makes with vertical, your dish should look similar to this, almost vertical
__________________
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 23-08-2008   #9
Could you help me out with how i would do such a thing ?
Old 23-08-2008   #10
Loosen the bolts, on the dish, just enough so that you can gently move it, side to side and up and down, then while able to view your portable television slightly move the dish until you get the strongest signal, then tighten up the bolts.
__________________
Mickha is offline   Reply With Quote
Old 23-08-2008   #11
My System: motorized fortec star
im not getting loads of channels on astra 28.2 got signal as high as i can do i have to adjust lnb to about 7 oclock then cheers
markjones is offline   Reply With Quote
Old 23-08-2008   #12
Thanks, ill try this soon.
In addition how do u adjust the lnb ?
as it is secured , i cant really twist it, etc
Old 23-08-2008   #13
Loosen the bolt around the collar. at the end of the arm, that holds the LNB in place, then twist it and re-tighten the bolt.
__________________
Old 23-08-2008   #14
just to let you know i havent sorted it yet as havent had a chance but here is a pic of the dish !
Old 23-08-2008   #15
Information Exec
The real test will be after we've had +60Mph winds, lol
__________________
Old 24-08-2008   #16
I seem to have sorted out the 'Level' - its stable on 87% but the quality is only 23% and when i search its not picking any channels up.
What shall i do now ? Does this mean its not facing the right direction, etc..
Old 24-08-2008   #17
Ignore the level, get the quality up and scan some channels in, then we will know if you're on the right satellite.
__________________
Old 24-08-2008   #18
How do i go about getting the 'Quality' up ?
Old 24-08-2008   #19
By gently moving the dish. Seeing as you're having all these problems I'd first check your cable connections are correct, even doing them again to make sure.
It just takes time, and patience, to gently nudge the dish to get a signal.
What transponder are you using to locate the signal ? Try 10788 V 22000 they are BBC 1 FTA channels.
Why are you trying to get Astra 2, 28.2E with your receiver? Your receiver is patchable and you would get far more viewing choice from Astra 1, 19.2E or Thor 1W, including live football, films and entertainment channels.
__________________
Old 24-08-2008   #20
Design Engineer/Installer
pedro2000uk's Avatar
My System: 75e-75w C & KU, 36v diseqc Anlg to HD Channel Master C120 dishes, stbs, lnbs, motors, too much to list
That dish actually looks very good but please make it far more solid before it blows over and you buckle the dish. That slab is a bit too small and you need to weight it down a lot more and ideally make sure it's on more solid ground. To reduce stresses you could lower the dish a bit for now if you can still see the satellite you want. You could use the T bracket to support it higher up... off that fence if it's solid &/or bolt it all to a bigger slab.. 3x2 etc..
That Silvercrest dish is quite light weight but it's when the wind blows as sat man says.. it acts as a sail and the leverage down to that small slab base can be substantial.. We used a larger slab and a very large plastic plant pot loosely filled with rocks, filled up with water (and topped with plants for looks and trelis up the pole) with the bottom leg of the K under the dish and the plant pot covering it. It was solid and looked good.
pedro2000uk is offline   Reply With Quote
Old 24-08-2008   #21
Thanks for the advice.
I will do what you said once i have sorted out the satellite and found what im looking for !
Im going for 19.2E now........ All cables seem to be fine and tight,,,,,,,,BUT now the bloody level is going crazy again and still only 23% quality
Old 24-08-2008   #22
With it switched off** Check the inside of all your f connectors for a tiny stray copper wire crossing to the middle. (always switch off before touching f connectors)
Last edited by pedro2000uk; 24-08-2008 at 02:53 PM Reason: switch off before touching f connectors
Old 24-08-2008   #23
What should i do if there is a 'tiny stray copper wire' ?
Old 24-08-2008   #24
Right im getting 66% quality now.....did a search on 19.2E and it found about 21 channels (lol)
When i go on the list there is about 400 channels though so i don't even kow which ones work, although one did appear to work then i cant find it again...it was a music channel. It also found a channel called Galaxie Sport , if that helps.
How do i get the rest to work ?
Old 24-08-2008   #25
I can get two working channels ( havent checked all 500)
Ocko TV
Public TV
[IMG] code is Off
Forum Jump
