Latitude tube angle. | |
| ASBO Club Member - Persona non grata Join Date: 26-08-2008 Location: Groomsport.
My System: CM dish, 1.8 Manhattan receiver. |
I have been doing a spot of maintenance on my Polar Mount by wire brushing to remove grime and rust spots. The wire brushing completely got out of hand by unscrewing the latitude adjusting nut. Can anyone tell me at what angle the latitude tube should be set at? My Latitude is 54.69 North, West 5.65. Jack. | ||
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m +Moteck motor.45E to 45W. 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | With the pole at the apex, it should be at an angle of (90-latitude) with respect to vertical, or your latitude with respect to horizontal.
__________________ | ||
| | #4 | |||
| Design Engineer/Installer Join Date: 08-08-2007 Location: Central UK near Jodrell
My System: 75e-75w C & KU, 36v diseqc Anlg to HD Channel Master C120 dishes, stbs, lnbs, motors, too much to list |
If you have only altered that angle then ideally you should get on your favourite satellite and adjust that to the exact middle with a meter or the on screen bars- tighten up and you should be back on the arc. You also should still see evidence of where it was unless you really did a good job cleaning it. | |||
| The Following User Says Thank You to pedro2000uk For This Useful Post: | sadza (28-08-2008) |
| | #5 | ||
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m +Moteck motor.45E to 45W. 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | Yes, you need to re-align your axis of rotation with the the Earth's polar axis, which happens to be 35º off vertical for your latitude.
| | #6 | ||
My System: CM dish, 1.8 Manhattan receiver. | | ||
| | #7 | ||
My System: CM dish, 1.8 Manhattan receiver. | Thanks very much, and appreciate your easily understood reply. Immediately after the Hammerite has dried I’ll be the busiest spanner boy in Groomsport. Jack. | ||
