Originally Posted by angusc ....edit.....I'm not worried about the side LNB being off the focal prime spot of hte dish as I can correct this by changing the satellite Degrees setting for each of the C-band satellites using the H-H Diseqc motor mount. |
The offset lnb will only actually be in the right place at one point on the arc as a proper working offset LNB... after you have moved to another satellite for the main lnb and then moved the motor to get the offset LNB as near as possible in the focal point it will be off the focal point....higher or lower than the focal point depending on the direction you have gone from where you set it up and which side is it is...
If you put it above or below the main lnb at your top dead centre sat and have incline actuator control then that would do it, you would just have one position for each sat and say about 5 degree up / down to bring each LNB in/ out of the focus point of the dish- the offset LNB would still lose a bit but not much- 5-10%.
Just side by side you may get it to work for the C with KU on offset to a degree but it's going to lose some on the KU.
The other problem is that dish size .. 90 for C really looks on the low size for those sats there. +42dbW in Beijing are probably get-able.. +45dBW will be easy-ish and give a bit of rain margin. The 40dBW C stuff (most?) will struggle on a 90.
see the Best .1 thread for KU LNB updates
