5 west | |
| Regular Member Join Date: 03-02-2007 Location: UK exeter
My System: technomate 6900 hd darkbox rev 2007 104cm gibertini dish. moteck 2100a with diseqc 12 |
hi guys what satelite is 5 west trying set my dish up what a nightmare up and down the ladder like a bloody jo jo lol | ||
| Information Exec Join Date: 07-05-2007 Location: South Midlands, UK & Lanzarote, Canary Islands, Spain
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | 5W is Atlantic Bird 3. You should be aligning your dish to this satellite as your longitude is fairly close. Have you followed the guides? SM
__________________ - .....A Detailed DiSEqC Motor Installation Set Up Guide HERE Motor Installation 'Quick' Reference Guide also HERE Satellites UK site Advertisers - | ||
My System: technomate 6900 hd darkbox rev 2007 104cm gibertini dish. moteck 2100a with diseqc 12 | yes mate have checked the latetude on the motor its set at 51 i have manage to get astra2 and astra 28degree only by useing disqet this is what i did i made sure the motor is set in the middle then got a compass took it up to the dish waited for it to settle then turned the dish pointing inline with the compass south i then went to the reciver put the usals on and sent it to thor digi film info then i went back up to the dish with my meter and tryed to get a better signal it went a little better not much then i tryed again again again again lol thats where i am just going get 2 more paracetamol loll | ||
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | I'm lost reading that. > Check brackets/Pole is dead straight in all directions > Make sure Latitude is correct on motor scale > Clamp the dish to the centre of motor shaft whilst on the ground and at zero > Goto USALS and enter YOUR latitude and longitude > Then send the dish to 5W > When dish stops, align the dish together with the motor around the pole and the dish elevation ONLY. > When you have a signal on 5W, tighten everything up. > Use 11.591 V, 20000, 2/3 for an active transponder if using the receiver to align and test (France 2,3 & 5)
| | #6 | ||
My System: technomate 6900 hd darkbox rev 2007 104cm gibertini dish. moteck 2100a with diseqc 12 | hi satman have had another go have checked all what you said pole perfect latetude set 51 on motor ect still cant get it the only thing i can think of is where iam pointing the dish when i first set it up pointing south so tomorrow iam going to point the dish at the sun at 11oclock is that right around that time thanks den | ||
| | #7 | ||
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | It's correct to align to a satellite as close to your longitude as possible but....... if you want to try sending the dish to 13e with USALS and then aligning to that first. You can then tell USALS to go to 5W and then correctly align as the software should take you to 5W or near enough there abouts. It's another option, that's all SM
| | #8 | ||
My System: technomate 6900 hd darkbox rev 2007 104cm gibertini dish. moteck 2100a with diseqc 12 | so is that right that i point the dish first at 11am where the sun is thanks for all your help den | ||
| | #9 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | You're getting too wrapped up in this initial positioning, nowhere in the guides does it give such importance to the approximate position. Your Due South position should be found by using the inline meter, or looking at a TV screen and manually moving the whole assembly on the mast and the dish elevation to find your due South satellite. If you think you may have an obstruction in the line of sight to 5W, then send the dish via the receiver to a different satellite and follow the same procedure.
__________________ | |||
| | #11 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Almost any will do, as it is a very strong satellite in the UK. 10949 V 27500-3/4 is as good as any.
| | #12 | ||
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | If you have a line of sight problem for 5W, you could also try 1W after sending the dish to 1W first of course Use the TV signal screen OR a compass (take a look at dishpointer.com)
| | #13 | ||
yipeeeeeeeeeeeeeeeeeeeeeeeeeee i have done it at last i set the dish to hotbird and have got the all without fine tuneing the dish thanks sateliteman for all your help you star mate anyone in exeter wants help setting up there dish let me know lol ![]() ![]() ![]() ![]() | ||
| | #14 | ||
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | ![]() Glad your up and running ![]() SM
| The Following User Says Thank You to satelliteman For This Useful Post: | den123 (29-08-2008) |
