Hi, guys,
I was getting really fed up with putting cheapo screw on F-connectors on, so I went out and got some water-proof compression type.
I can't believe how easy they are to do, and all this time I've been messing about with the crappy screw on type.
They are such a joy to put on I'm going to replace all mine (all 20 of them) for decent ones.
I think I have done them right.
I cut back about 1 cm right to the core and then about another half cm just the outer sheath, then shoved it in, and compressed it with the tool.
Robbo
