Did my first install today but help with dual lnb
Thread Tools Display Modes
Old 28-08-2008   #1
My System: DM500s
I managed to setup my first self install today thanks to the great guide stickied at the top and got hotbird yay.
i have an arm and additional lnb which i would like to install to pickup 19 too.
Which is the best way to do this? Hotbird is aligned, is the best way to just screw the lnb on and move it around till i pick up 19 or what?
Like i said had a search around but couldnt find anything on installing a dual lnb setup, forgive me if i missed it.
many thanks.
bigfish is offline   Reply With Quote
Old 28-08-2008   #2
Information Exec
satelliteman's Avatar
Location: South Midlands, UK & Lanzarote, Canary Islands, Spain
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N
Welcome,
Good result with your install
leave the dish aligned to 13e and install the LNb bracket. ( you don't say what dish or bracket you have)
Anyhow, standing in front looking at the dish, place the LNb for 19e on to the left hand side. You'll need to raise this LNb a fraction to compensate for the elevation difference. You can also align to 19e and 13e to the right.
See 'offset guide' :
Offset LNB Guide - Pdf
for more info
SM
__________________
A Detailed DiSEqC Motor Installation Set Up Guide HERE
Motor Installation 'Quick' Reference Guide also HERE
Last edited by satelliteman; 29-08-2008 at 03:47 PM Reason: broken link location, now correct
Old 28-08-2008   #3
My System: DM500s
thanks for the quick reply, im using a orbital 80cm and an appropiate holder. Actualy i stripped the dish from where i was previously living and both lnbs and the holder is already in place but i wanted to dismantle it and do it myself out of interest lol. I aligned it using the left lnb to hotbird, tomorrow ill take it off and do as you sugest and see if i can do it.
thanks
Old 29-08-2008   #4
My System: DM500s
hmm i moved the dish to another location and i dont seem to be able to pick anything up(using sat reciever as a meter) dispite screwin around for an hour with it. I cant see the tv well from this location so I have one of them crappy satellite finders that i want to use, when i plug it into my reciever with the little cable it lights up like a xmas tree but when i go outside and plug it in the long cable its just dead. Is there any way i can check the cable with a voltmeter that i have? Tried messin about trying to get a reading off the lnb on the meter but couldnt get anything, is it possible? as id like to eliminate the cable being screwed before i waste some more time.
Old 29-08-2008   #5
My System: DM500s
bingo worked out how to check the voltage, getting 13v inside with a small cable and 0.13ish outside so that explains why i wasted an hour pointing the dish like a mug lol.
Old 29-08-2008   #6
My System: DM500s
managed to align the left(as im facing the dish) lnb as you suggested to 19 but im having no luck atall getting the other lnb to pickup 13. not even by moving the dish would it "lock". i think i might just buy a monoblock that would be easier wouldnt it.
Old 29-08-2008   #7
rolfw's Avatar
The LNB will not be very far away in the offset position, probably only a centimetre or so.
You say you aligned the left hand LNB as you're facing the dish, is this in the main holder, or is it the offset one?
__________________
Rolf
Donate
Old 29-08-2008   #8
My System: DM500s
yep main holder is to the left as im facing the dish. i have the second lnb positioned roughly 2cm to the right of that. (no more than 2cm). Im using dishpointer.com to give me the line i need to position in relation to my garage, when i select "13 and 19" multi lnb setup the line is the exact same position as it is when i select 13. But when i select 19 there is approximatly 1m difference on the garage(which is aprox 5 meters away from the dish). thats confusing me slightly if you could clarify if i should have the main lnb pointed at the line of "13 and 19" and "13" or the line of "19"
If you get what im saying sort of..lol
Old 29-08-2008   #9
rolfw's Avatar
Set the main LNB to 19 East and lock up the dish, the job is then done on that LNB and the dish alignment. Then by moving the right hand LNB (looking from behind the LNB towards the dish face) find 13 East, don't use the DiseqC switch yet, connect direct to the LNB, at first move the LNB until it is touching the central one, it also needs to be slightly lower.
__________________
Rolf
Donate
Old 29-08-2008   #10
My System: DM500s
ok thats very clear thanks very much ill give it a try
Old 30-08-2008   #11
My System: DM500s
fantastic, did it today and your advice worked perfectly thanks very much
Old 30-08-2008   #12
rolfw's Avatar
No problem, glad you got it sorted.
__________________
Rolf
Donate
[IMG] code is Off
Forum Jump
