nilesat 7w north midlandsInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| | #26 | |||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorks, uk
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | on that size dish, you will be best to use the channel master feedhorn and an invacom c120 lnb also what receiver are you using as you will need one with a good tuner in it | |||
| | #27 | ||
| Member Join Date: 01-09-2008 Location: england
My System: all new to this want to watch showtime on nilesat 7w looking for advice | the lnb is andrews feedhorn with inverto0.3db c120 lnb and the receiver is a technomate 5400+ any advice. the thing is it picks up loads of nilesat channels but nothing on transponder 15 the engineer fitting it cant a reading on his meter for it | ||
| | #28 | ||
| Regular Member Join Date: 04-09-2006 Location: Kent, UK
My System: Sky; Raven 90 multi-LNB 1W, 7E, 9E, 13E 16E, 19E; 1m Orbital dish on Moteck SG2100 motor; Technomate 1500, Phoenix Apollo and Kathrein (analogue) etc etc Receivers | One would have thought a dish of that size should readily pull in Nilesat H TPs! Anyway, if the verticals are constant during the day, could you wait till about 10 PM and then check some of the H TPs especially 11996 and 11919. Generally, you are more likely to get best reception from about 9 PM through the night; thus, testing for signal (and any change in signal quality) may just be easier around then. | ||
| | #29 | ||
| Member Join Date: 02-11-2007 Location: Land of hope & glory
My System: Orbitron MicroMesh 3.6m dish with C/Ku Co-rotar.Nokia Dbox1 Nokia Dbox2,EchoLink EL-700 Fta+.Drake ESR 2000XT + Echostar LT8700 | For H transponders i would try 12303 H 27500 3/4 (TP 31) and tweak to maximize the signal, skew the lnb and then try the showtime transponders. | ||
| | #30 | ||
My System: all new to this want to watch showtime on nilesat 7w looking for advice | the engineer has got a signal on his meter with a picture on the testing kit and a pass signal, when he connects it to the receiver we get no signal, tried 3 diffrent boxes and nowt anybody any ideas | ||
| | #31 | |||
My System: Orbitron MicroMesh 3.6m dish with C/Ku Co-rotar.Nokia Dbox1 Nokia Dbox2,EchoLink EL-700 Fta+.Drake ESR 2000XT + Echostar LT8700 | need more information
but where are you connecting the recievers, inside the house or outside near the dish? | |||
| | #32 | ||
My System: all new to this want to watch showtime on nilesat 7w looking for advice | when he connects to the meter inside the house he gets it on a small screen but nothing from the reciever (s) | ||
| | #33 | |||
Connect a short cable from lnb to reciever and see if you get a signal. | |||
| | #35 | ||
| Design Engineer/Installer Join Date: 08-08-2007 Location: Central UK, E Cheshire ..near Jodrell
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions... | can't you test the h's on 8w?... or turn the lnb 90 degrees....and swap the tp 15 to v in the stb to test that | ||
| | #36 | ||
| Member Join Date: 04-08-2007 Location: Staffordshire
My System: Sky IRS & Hotbird | I'm the engineer concerned on RR's dish, I use a Rover analyser and can get all the Vertical channels no trouble whatsoever, When I change frequencies on the meter it still comes up with the same listings as on the transponder settings, but in order to get a signal at all on that setting, I have to turn the lnb 45 degrees (move it from 6 to 9, Having never installed a 2.4m dish, but doing IRS systems the only conclusion I can now come to is that the LNB is faulty and not receiving the Horizontal channels whatsoever, we are definately on the right bird as we get all the listings for ShowCinema. | ||
| | #37 | ||
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions... | It could be a faulty lnb .. but you know by now that the H's are far harder than the verticals which you could get on half the size there btw.. 45 degrees doesn't compute ... try swapping the polarity in the stb of 11919h to 11919v (a stronger H tp) and turn the lnb 90 degrees that will tell you if it is the lnb not switching to H.. BTW ... what numbers on the tm do you get City 7s tp? (11862v) | ||
| | #38 | ||
My System: Sky IRS & Hotbird | Pedro, RR will have to tell you that As I'm not there now. We have spent all day there re-aligning, re-skewing etc etc, but with no luck whatsoever on the Horizontals. As you can see from the picture section on my site the cable run isn't very far either as the room it goes to is just to the right of the dish as you look at it. Website address Removed | ||
| Last edited by satelliteman; 28-09-2008 at 09:07 PM. Reason: Removed Live Link - SM | |||
| | #39 | ||
My System: Sky IRS & Hotbird | Website removed Again and it's not too far from the room either (maybe 10 m in total) I'm not there now Pedro, but RR may be able to tell you | ||
| Last edited by satelliteman; 28-09-2008 at 09:07 PM. Reason: Removed Live Link | |||
| | #40 | ||
My System: Sky IRS & Hotbird | Pedro, when I say 45 degrees, I lined the dish up with the lnb pointing to 6pm, when I found that none of the Horizontal channels were working, I put my meter onto transponder 15 (11.996.00) and skewed the LNB until it was then in the 9pm position, As most of us know, we should have picked something up on there well before that before the Vertical channels started showing again, I use a Rover ST4. So assume everything is cushty, I lined up originally on T14 and got it no trouble whatsoever. | ||
| | #41 | ||
| Regular Member Join Date: 20-07-2007 Location: London
My System: Channel Master 1.2m and 1.8m, Vantage VT-X221TS CI and 8000s, Technomate V-Box II, 18" Superjack actuator | If you've got your dish set to get the strongest signal on the 7w verticals then you can check the high powered 8w European beam frequencies without moving the dish. If you can get the verticals and not horizontals then it would be the LNB. | ||
| | #42 | ||
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions... | to be setting up on 7w and just happen to have an lnb that is nackered on the H polarity is.. really unlucky. 6pm to 9pm = 45 degrees? btw .. you need to upload pictures on here.. quick process. you in N Staffs? | ||
| | #43 | |||
| | #44 | ||
My System: Sky IRS & Hotbird | Evening RR, Attached is a photo of the dish we've put up. Pedro, RR is going to contact the dealer tomorrow to try and get a new LNB sent out, I'll also try the other options when I next go back. We are in Stoke mate | ||
| | #45 | |||
| | #47 | ||
My System: Sky IRS & Hotbird | Yes it is Michael, the back plate is massive, I have to say it was not me that fixed it there. But it is above a flat roof so RR has to be careful that he didn't damage the roof. | ||
| | #48 | |||
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions... | I was 10 minutes away this afternoon .. could have let you check it with another c120 (or box of lnbfs) ... we do steel work if you get any problems with that wall mount... | |||
| | #49 | ||
My System: Channel Master 1.2m and 1.8m, Vantage VT-X221TS CI and 8000s, Technomate V-Box II, 18" Superjack actuator | Wow, I can see how big the plate is! My 1.8m is really heavy so I can imagine the weight of a 2.4m. I personally opted to put mine on a non penetrating roof mount. I've added a picture. I need to add some patio slabs to mine soon before the strong winter gales come. | ||
| | #50 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | | ||
| midlands, nilesat, north |
