nilesat 7w north midlands
Old 28-09-2008   #51
My System: Sky IRS & Hotbird
SM, when I skewed the LNB, the signal came up on the Horizontal channels, Not sure whether you are conversant with a Rover st4, but when I then checked the Mpeg settings which gives you a list of the channels on that TP, it was exactly the same as T16 which is a Vertical TP. This is why I am pretty confident it is the LNB.
NeroAer is offline   Reply With Quote
Old 28-09-2008   #52
BoSSpak's Avatar
My System: Orbitron MicroMesh 3.6m dish with C/Ku Co-rotar.Nokia Dbox1 Nokia Dbox2,EchoLink EL-700 Fta+.Drake ESR 2000XT + Echostar LT8700
Wooow !!! thats some risk you taking having it fixed to the wall. I just hope that doesn't pull the wall off during high winds!.Plate or no plate m8, andrews 2.4m dish is bloody darn heavy.
BoSSpak is offline   Reply With Quote
Old 28-09-2008   #53
rolfw's Avatar
Real name: Rolf
I would perhaps consider putting an acroprop underneath it and guy wires to both sides from the mast.
Rolf
Old 28-09-2008   #54
CROSSBONES's Avatar
My System: 1.2M, & 55cm Gregorian Dish`s, 1.8m Precision dish Jaeger 1224 H-H motor.Dreambox 800, Vbox-II. SS2 Card.
Yes the 1.8m is heavy enough, I would be very concerned with a dish of that weight, and its over the flat roof!
CROSSBONES is offline   Reply With Quote
Old 28-09-2008   #55
satelliteman's Avatar
Real name: Paul
I have and use a Rover ST-4 daily.
You can switch V & H by holding down the 'barscan' button for more than 2 seconds. Change to H whilst still on Tp 15. Go back to trace screen and you should see just noise if the LNb is at fault.
satelliteman.
An Installers Choice
Follow us on
Old 28-09-2008   #56
Design Engineer/Installer
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions...
have you tried it without the meter .. just on the tm's on screen meters and do the h to v swap on 11919h?
pedro2000uk is offline   Reply With Quote
Old 29-09-2008   #57
Robbo's Avatar
Real name: Mark
I think a better way to test the LNB would be to go for a VERTICAL transponder, like 11862V for example. Then rotate the LNB 90º, and change the V to H in the tuner.
Either that or stick the LNB on the nearby minidish.
As at this point, we don't know that the dish and LNB combination and alignment are good enough for the horizontal transponders.
Old 30-09-2008   #58
My System: Dreambox
I just wanted to share my experience with Nilesat here in Belgium, near Brussels.
I started with a 180cm PFA Jonsa. I got good results with the vertical transponders, but weak signals on the horizontal ones.
Then I bought a 150cm Gibertini, thinking it might outperform the 180cm Jonsa, due to better build quality. Well, reception with the Gibertini was weaker than with the Jonsa...
Then I bought a 240cm PFA from Aerial Oy (Finland). There I got excellent results with very strong reception on the horizontal transponders.
Then, at the end of August, I had the chance to test Nilesat with a 110 Triax. Location: just 20km from the first location.
Results: better reception than the 150cm Gibertini and the 180cm Jonsa, even though receiver, lnb, multiswitch and cables were the same!!!
Conclusion: Nilesat really seems to have hotspots and coldspots with its out-of-footprint reception. Just 20km difference can make a big difference.
My results were posted in the German forum dxtv dot de, under the section "Extrem-DX > Inmarsat, Space-Station, SeeSat, Sat-Spionage". You will find there a map and all measurements.
charly20 is offline   Reply With Quote
The Following 2 Users Say Thank You to charly20 For This Useful Post:
divibi (30-09-2008), pedro2000uk (30-09-2008)
Old 30-09-2008   #59
Thanks for that excellent post there, 7w signal hotspots & coldspots are a major issue that make it difficult to predict .. local interference from a city can alter reception too.
... was that 20km nearer?
Old 30-09-2008   #60
My System: Dreambox
yes, I know it is crazy such differences in reception of Nilesat with such small difference in location.
Here is the map of the 2 locations, just out of Brussels. Green dot is the first location with the 240cm dish; red dot is the location with the 110cm Triax.
Of course, the 110cm does not get a as good reception as the 240cm, but netherless it outperforms the 180cm Jonsa and 150cm Gibertini just 20km away.
The second location with better results is just a bit further away from Brussels, with more green / nature around. Is this the case of the difference of reception, or simply an issue of hotspots and coldspots with out-of-footprint reception?
In any case, it is very hard to predict in advance the strength of reception with out-of-footprint reception. Only first hand experience pays off. And, yes, it can be costly to gain such experience.
nilesat 7w north midlands-picture-7b-jpg
Old 30-09-2008   #61
Was the Jonsa 180cm the 6 panel prime focus petal dish and made from 'quite thin' steel.
Old 30-09-2008   #62
My System: Dreambox
unfortunately, yes.
Old 30-09-2008   #63
It is branded Fortec Star here .. well known to be very difficult to align (for KU band) and in need of some strengthening before you leave it out in a draft but very, very cheap and performs OK in KU band once it's setup really well.
Did you find it difficult to setup to get full performance out of it?
Old 01-10-2008   #64
My System: Dreambox
oh yes, it took me a long time to fine tune it in order to get the best reception out of it.
Old 01-10-2008   #65
My System: all new to this want to watch showtime on nilesat 7w looking for advice
any idea how to tell how good the signal is or if its a cold spot, still no joy with horizontals the verticals are pulling 90% and between 65-70 qualty so, would it be that good for verticals if it was a coldspot
riproaring is offline   Reply With Quote
Old 01-10-2008   #66
What satellite box is that?
Old 01-10-2008   #67
its a tecnomate 5400+ how do they rate
Old 01-10-2008   #68
Real name: Paul
I would of thought you'd be up and running by now.
Wasn't it just an LNb replacement for the Horz for 7W ???
satelliteman.
Follow us on
Old 01-10-2008   #69
yeb its coming tomorrow so fingers crossed
Old 01-10-2008   #70
I think they are one of the most sensitive about- a couple of others beat them.
What I see is a lower quality level for the verts than I'd expect although the power is there ..
You had an LNBf on it in the picture didn't you, how did that do and did you look at other sats or take the LNB off and hold it in offset to another sat to just check the H's on that lnb? (nick that sky lnb)..
btw... lousy weather for it eh? can't always choose but it's been a paperwork day today... new energy efficiency regs & er.. planning regs funnily enough he he ...
Old 02-10-2008   #71
its finally up and running thanks for advice chaps
Old 02-10-2008   #72
Real name: Paul
Assume the LNb replacement has got you working, both V & H transponders.
satelliteman.
Follow us on
Old 02-10-2008   #73
yep although the horizontals are still a little low around th 50 mark
Old 08-10-2008   #74
keano's Avatar
My System: 2.4mtr Channel Master Dish, Fracarro Penta 85cm Dish, 64cm Traix Dish with 4 multi LNB'S Sky HD, Dreambox 800, Dreambox 500, IPBOX 250, Sky HD and a mad wife !
Not been around here for a while and just had a look at this thread.
Firstly I can not believe where you have put the dish, the weight of the dish and the size of it if we get a storm then it will take the wall down, i would be sh*tting myself evey night in bed.
When I put mine up last year it tooks two of us just to lift one of the sections up into postion.
OK I see you have it working now but just to let you know that I found the narrow band feedhorn better than the standard feedorn.
See the pictures below.
nilesat 7w north midlands-perfroms-better-jpg   nilesat 7w north midlands-gives-2%25-less-jpg
keano is offline   Reply With Quote
The Following User Says Thank You to keano For This Useful Post:
pedro2000uk (08-10-2008)
Old 18-11-2008   #75
can anyone give any tips on improving the H signals only around the 50 mark and if a cloud parks up next to me it drops out or even goes off
midlands, nilesat, north
[IMG] code is Off
