nilesat 7w north midlands
Old 18-11-2008   #76
satelliteman's Avatar
Real name: Paul
If I recall, you have a fairly large dish already for this sat (Andrews 2.4)
I would just make sure the skew and alignment is spot on; it's a weak satellite here and is the H polar.
satelliteman.
An Installers Choice
Follow us on
Old 18-11-2008   #77
trigger's Avatar
My System: 30W,7W,13E,16E,19E & 28E Dishes everywhere Darkbox 2008HD Sly+ V3
A few of things I have found here with CM 2.4īs
Check the 2 parts have been bolted together correctly - Its amazing the amount I have been to where they are poorly put together.
Also pull on the 3 lnb support arms one at a time to check if the lnb is being illuminated by the whole dish. Again by "slightly bending" the arms in or out the signal can be improved slightly and this just may be enough.
On older dishes they seem to open out over time - try knocking a wedge between the dish and the support mount at the bottom of the dish. This forces the bottom up and in slightly - again this may be just enough.
trigger is offline   Reply With Quote
The Following User Says Thank You to trigger For This Useful Post:
pedro2000uk (18-11-2008)
Old 18-11-2008   #78
GreenmanBelg's Avatar
My System: 1 x CM 1.2m matching C120 feedhorn and Invacom 0.3db twin output LNB.50 degrees East to 42 degrees West.1 x CM 1.2m AZ/EL mount matching C120 feedhorn and twin output Invacom 0.3db Humax VACI 5300 Old Panasonic Digibox with IRL $ky sub. Coship FTA
Wink
Originally Posted by NeroAer View Post
Evening RR,
Attached is a photo of the dish we've put up.
Pedro, RR is going to contact the dealer tomorrow to try and get a new LNB sent out, I'll also try the other options when I next go back.
We are in Stoke mate
I love that dish.
Regards JD Belgium.
GreenmanBelg is offline   Reply With Quote
Old 18-11-2008   #79
Design Engineer/Installer
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions...
Originally Posted by riproaring View Post
can anyone give any tips on improving the H signals only around the 50 mark and if a cloud parks up next to me it drops out or even goes off
What LNB have you got on it now and what LNBfs / c120s have you tried....
pedro2000uk is offline   Reply With Quote
Old 18-11-2008   #80
My System: i have a tm-5400 c1+ not sure on dish sive i inherited it
talkig of long and lat once i have found them for my area how do i go about changing them on my techno5400 my handset doesnt do underscores lol you can tell im a newby cant you ? lol
micric is offline   Reply With Quote
Old 18-11-2008   #81
trigger's Avatar
Just another quick note.
Whoever imported the CM dishes to this Island obviously didnīt bother with the matched feedhorns as I have worked on about 15 over here and seen only one fitted.
Anyway the point is that the only other LNB we have found to work successfully is the Large ALPS 0.6 Quad - even though its 0.6 they work well on the low frequencies we want far 2D. Light grey in colour with a silver manufacturers sticker. Anything else that has been tried does not work very well.
Old 19-11-2008   #82
My System: all new to this want to watch showtime on nilesat 7w looking for advice
on now is inverto universal lnb i think its a c120 with feedhorn 0.3db also tried titanium single lnb 0.2db 10.7 12.75 ghz if this doesnt make sense let me know i am not very well read on this sort of kit
cheers
riproaring is offline   Reply With Quote
Old 19-11-2008   #83
pedro tried send you a pm i think your box is full mate
Old 19-11-2008   #84
sorry.. done..
Old 27-11-2008   #85
My System: sky tv only but looking at a motorised system
Hi I am also trying to get showtime in kiev , if anybody has any ideas at all it would be a massive help ???
skysterose is offline   Reply With Quote
Old 15-12-2008   #86
My System: tecnomate 5400 1.2 motorised dish 1.8 precision
riproaring where about in stoke on trent are you and did you get the dish working on showtime im looking at a 1.8 andrews for stoke on trent just wondered how you went on thanks
combridge is offline   Reply With Quote
Old 15-12-2008   #87
hi pedro im in stoke would you think a 1.8 andrews would work in stoke thanks
Old 15-12-2008   #88
sorry I didn't see your post... too busy trying to do the same job when you posted I think...
It's difficult to predict for anywhere... just going off the fact that your latitude is much closer - similar to the south coast of the UK where reports say a smaller dish can be used ....and your longitude may give further benefit (or not)... but as everyone knows.. these signals are far outside the footprint maps so we are relying on the fact that 7w is a big coverage area which is also more difficult to contain compared to a very focused beam.
A guess would be for Showtime's main H (sport) tp... a decent 1.2 from Kiev... and 100% setting up with a sensitive stb/ lnb/ cable etc... and a low interference area .... a decent 1.8 etc... for decent rain fade ...
but the best advice is to try to get as local information as possible.
The Following User Says Thank You to pedro2000uk For This Useful Post:
divibi (15-12-2008)
Old 15-12-2008   #89
You might do it to a degree if you have a rural location with little local interference (neighbours, power lines, telephone lines/poles, radioactive sheep) and it's set up 100% etc.. Whether you would get it consistently I think probably not..... (but would hope you do it).
A 2.4m can get showtime's h (sport) tp in N Stoke but it has to be installed 100% and local interference can become a problem, not just the stuff that the cable can pick up but how a dish that size can amplify anything nearby into the feed horn along with the feint signals barely getting through from the weak h's.
divibi (16-12-2008)
Old 15-12-2008   #90
Site administrator
Analoguesat's Avatar
A decent 1.8m might give you a chance, but if you are thinking of buying one of the cheap and flimsy 1.8m dishes from maplin forget it - you need to be looking at several hundred pounds of well engineered dish (With no guarantee it is big enough!)
Analogue forever!
Old 18-12-2008   #91
hi again pedro im now going to buy a 2.4 andrews to make sure i get showtime. whats the differance between a channel master and an andrews as the one i have seen is a lot of money.would this mean i d get all the channels on showtime with this system and you do no where abouts in stoke on trent riproaring is based thanks
Old 18-12-2008   #92
Question
Where are you going to buy it? The latest owner is ASC Signals. The main hardware remains the same.
Regards JD Belgium.
Old 18-12-2008   #93
Andrews/ Channel Master are ASC Signal now and the 1.8s & 2.4s use the same model numbers/ design.. 183s & 243s with tx & tx/rx KU & C band feed options .... and the same crude AZ/EL mounts..
see _http://www.ascsignal.com/html/vsat_pdfs.html
If you get a used one, try to make sure it was previously installed 100% and follow all the installation docs 100%. If a face/ join seem was installed badly there is no telling if that material could keep a distortion or would spring back 100%, especially if it was exposed to very hot weather while bolted twisted -over tightened for a prolonged period and it's not easy or cheap to test a dish of that size. Their quoted tolerance is .025" (0.63mm) max on the seem and above that won't do (better as near to zero as you can) and the face should not be stressed at any point in installation or over tightened or tightened out of order.
If it's used commercially for VSAT etc.. the size would be spec'd at over kill to ensure continuity but on 7w weak Hs in mid UK, everything needs to be 100%. The pole has to be to spec or higher and perfectly vertical and have a level/ square cut top- even if you are not motorising it... if it's out you don't know where you are when you come to really fine adjust the AZ/EL .. add that to the really crude galvo dipped az/el (fine?) adjusters and it can be frustrating ...hmmm. (It's a good idea to grease those- not on a locking surface- use washing up liquid on those). If I got the opportunity/ time I would replace the AZ/EL adjusters for far better engineered equivalents...
If you want to try LNBf's on it, the focal length of the feed horn throws it forward 5-10mm so it needs a long neck LNBf like the Edison (or a bit of a mod) to get the best out of LNBfs ....
(north)
divibi (19-12-2008)
midlands, nilesat, north
[IMG] code is Off
