All,
I have scanned through many of the threads on this page and would like to put a system together now. I consider myself technologically-savvy (e.g. build my own PCs) but find this stuff confusing at the start! My situation is as follows:
I live in a flat without a communal system. There is scaffolding up at present and for some months ahead so I can not install a dish on the back of the building as my neighbours have done (scaffolding right up to the edge). However, I have a balcony that is S/SW facing and would like to install a satellite on there. I already have a
Sky subscription from my old flat but would rather do the new install myself! My questions are:
1) I am intending to buy a Triax dish. Is 80cm too large? Would, say, 60cm be enough?
2) I was going to fix a Titanium 0.2dB LNB. I assume a dual one is enough, will there be any advantage in installing a quad one?
3) Is there any particular make of cable from LNB to receiver that is recommended?
4) Does anybody know a reasonably priced tripod? This seems to be the trickiest bit as lots of stuff is meant for wallmounting and I have no idea how stable the tripods are.
5) I am assuming the signal will be able to come through the scaffolding as there is a gap of around a foot between each horizontal spar. Is this a dumb assumption?
6) Finally, finally, should I aim for a motorised system or, as I suspect, does it make sense to start with the basics?
I appreciate these are pretty basic questions but at the start of the week I did not even know about Triax dishes and titanium LNBs so I have made some progress! Any help much appreciated.
