Originally Posted by Rd100 I have tried the feed horn in all places and the smart still beats it |
Yep, we improved on the outputs of the dedicated feed horn+c120s by tweaking the focal length.... but it still didn't beat the smart 40mm lnbf or the one/s that beat the smart..
I think a £3.99 Lidl .2 lnb (silvercrest) was one of the ones that beat the smart.
What lnb holder did you use, the one for the dish? and did you try modifying that focal length wise?
At the designed fixed point for the 40mm lnb holder, the LNBfs we tested would have given a certain order of performance (most still beating even the tweaked feed horn/c120s)... after we re-engineered the 40mm holder for each lnbf's best focal length beyond the normal adjustment, all the numbers went up but the order changed on which was best.
