Yes, database is quite old - If anyone will provide more recent TP listing - this will be great. Now I'm adding search history & export - program will record which frequency you entered, to which sat it belongs, and will allow to save this data into file, so you will know, which satellites you've captured, while sitting on the roof
Also, you can throw in your .ini files - program will index all of them, just keep them in format as default ones are.
P.S. I wrote this software, due to limitations of ASUS EEE PC. I bought 2G SURF model quite cheaply, for $120, and my idea was to download complete lyngsat satellite database, put it into eee, and install google desktop search, to quickly find required satellite. But after I installed Windows XP on it, I discovered that I have not much free space left, so lyngsat won't fit there in any way. So I had to wrote this program
