Motors with metal gears?
Old 23-09-2008   #26
Satcom1's Avatar
My System: 1 Meter Primestar Elliptical C/KU. Twinhan 1025 PCI(Linux), Coolsat 6000, Winegard 76 cm dish. 8' Unimesh, HCC9300 Receiver. Diamond 9000 HD, 1m prime focus, 1.2 m prime focus, both on C Band.
Though defeated by the evil Fresnel this warrier will return victorious!
Arrow SG2100 Motor
In USA the Digiwave motors are sold as SG2100 and newer model SG6000. The SG2100 is also branded Motek by some vendors.
In the picture from Rolfw post above you can see the PCB is marked SG2100.
There were three different versions of this motor here the 'One button" motor was considered the best. Some do diseqc 1.2 only and some do USALS. However, they likely don't have license from Stab to use USALS.
Plastic gear or metal gear will run smooth and quiet if "Backlash" is adjusted properly. Backlash Adjustment of Moteck SG-2100 has instructions on adjusting backlash.
From what I've seen, the original SG2100 was a Tiawan product. China took over production at lower cost, greater profitability for vendors. Quality control was terrible at first. Now with SG6000 better quality and better design. With SG6000 they copied the Stab mounting bracket and solved the bracket deformation problem with the SG2100.
The DG series has the metal gear but does not seem to work any better for 1.2 meter dish.
Satcom1 is offline   Reply With Quote
The Following User Says Thank You to Satcom1 For This Useful Post:
divibi (23-09-2008)
gears, metal, motors
[IMG] code is Off
