Motors with metal gears?Information exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Regular Member Join Date: 28-08-2005 Location: Nottingham
My System: 'Fortec Star Passion' (& a dead SL65) One of them big Woks on the outside, and a thingy that moves it about a bit. |
The dark Motor boasts metal gears? But has anyone had gears fail on their motor? I take it non metal gears are nylon or similar? | ||
| The best way to learn is from your mistakes... Sorry I made a mistake!... The best way to learn is from others mistakes. _www.Nottstalgia.com The Nottingham Forums | |||
| Archived Member Join Date: 13-08-2007 Location: Middle East - Israel
| I will consider using this motor only when I have full details about the real OEM manufacturer, their location, address and their quality control procedures. Until then, I would stick to motors made by either Moteck or STAB, with a preference to Moteck according to the good experience by many members of this forum. | ||
| The Following User Says Thank You to HB13DISH For This Useful Post: | divibi (20-09-2008) |
| Design Engineer/Installer Join Date: 08-08-2007 Location: Central UK, E Cheshire ..near Jodrell
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions... | Depends what the metal is and what the plastic is ... some cheaper alloy’s mechanical characteristics are not as good as some plastic’s for that job... metal can be noisier too.. Hard plastic gears are probably better at the job at the high geared end. Don't Satellite Superstore say Technomate are the stronger of the diseqc motors and they wont spec any others other than 36v stuff... | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Some would say DiSEqC motor and 110cm is a no go especially if sited in an exposed location... although I have seen many with the Stab motor | ||
| | #5 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Yep, got mine 6ft off the ground on a stab 90, but have a Moteck on Standby though. | ||
| | #6 | |||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | I still like the Moteck, as with only one exception, the brand has worked flawlessly for me. I've installed a Stab for a customer to move a Gilbertini 120cm and didn't like the backlash which appears to be a feature on all of them, but there again, I think the Gilbertini 120cm is too big for any of the current style of DiseqC motors, even with metal gearing. | |||
| | #7 | ||
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions... | I'd give STAB or Superjack a vote too on a 1.1 Triax sheltered... not sure about the Turner 2100 incarnations (Maplin)... on 1.1s... | ||
| | #8 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | What about the jaeger 99G and the Td110, would make a lovely couple | ||
| | #9 | ||
| Specialist Contributor Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | oem manufactor,of the modell darkmotor that is avalible in uk from al*sat ,is Golden Interstar! Type Golden Interstar GI-50-120 technicly exactly the same,only colotor is difrent! Price here is 50€ moving range up to 80 east also good for heavey antennas,specification says up to 14 kg! Staab hh 100 i was using one year,and then the motor,lost his mind and all his positions! | ||
| The Following User Says Thank You to Turok For This Useful Post: | divibi (20-09-2008) |
| | #10 | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorks, uk
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | | ||
| | #11 | |||
Why do you think that Golden Interstar is the same as Dark Motor? Do you have their address or real website? On some of the labels, I can see a STAB logo. So perhaps it is made by STAB after all. All I get is a lot of links to German websites, so it is possible that this is another variety for distribution in Germany and the real OEM is still unknown. Do you have a spec where it says it has metal gears (spec in any language will be fine). Please attach it. | |||
| | #12 | ||
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | Hello ! translate the specification for you! with google translator hope its corect! ore quiet, compact and powerful DiSEqC motor with very precise mechanics. The engine is easy on the coaxial cables connected with the receiver. Controlled the engine with DiSEqC following protocols: - DiSEqC 1.2 - USALS (DiSEqC 1.3) - Goto-X Specifications of the IGolden Star DiSEqC Motors GI 50-120: • Power on receiver: 50 mA (standby), 200 mA (typical), 350 mA (maximum) • Output: 13 / 18 volt DC (corresponding to the input voltage) • Compatible Receiver: DiSEqC 1.2 receiver and receiver with Interface Box • Movement speed: 1.9 ° / sec (13V) 2.5 ° / sec (18 V) • Limit / - 80 ° • Fixing on the diameter 35 - 65 mm • Programmable satellite positions: 60 • Supported Protocol: DiSEqC 1.2, USALS (DiSEqC 1.3) and Goto-X • Maximum size antenna up to 140 cm,some say 120,but only darkmotor box i read also 140cm • Connection via F-connector • LED display function (2 colors) • Input Voltage: 13 / 18 volt DC • elevation angle (latitude angle change): 10 ° - 75 ° • Function (calibration) "Go to 0 position" built (Go to 0 °) • The positioning is on a high resolution sensor realized Hahl • azimuth angle (spherical polar coordinates) 80 degrees East - 80 ° West (160 ° max) (same moving range then darkmotor)curencly no other diseqec motor moves up to 80 west7east/current products stop at 75 east! • 26 positions over 1 satellite built satellites already preprogrammed table • limiting protection of software (software programmable limit) and hardware (via micro switch) integrates here on Ebay 150295796262 first i bought the darkmotor,and after that i find out that the above modell is exactly the same,for only the have price ![]() only the color is difrent! dark lnb darkbox etc,everthing is oem made saled under diffrent name! most we see this are on the stbs ,a big factory in korea 10 difrent modells,insinde all the difrent bootloader and outside difrent box! finish is the new receiver,or product! you only need alot of money,told the factory,in Asia what you want,but it only works in large figures! dont worry,Hb13 evrrything i write,i checkt it first is information corect or not,it takes a long time,to test and investigate! the technical "problem" is,not every receiver,is 100% compatible,in its usals protokol to move outside 62 East,to eastern satelites! this the reason,that for e.g staab motor,is the limit 62 east,because,it is not supportet by the protokoll itself! that means all satelite behind 62 erst,you must tune,in manual diseqec mode! in the moment,the usals specifcation stands at 1.3 but most of the receivers,on the market,does not support,the full automatic moving range of the motor! some newer modells will do,without tuning manually,but currencly i only know that the exitis,but dont find it yet! what you think about this? | ||
| | #13 | ||
| Regular Member Join Date: 15-06-2008 Location: Birthplace of Television
My System: Cuberevo Twin HD on a 85cm motorised Fracarro Penta dish. Superior Dark Motor. Inverto BLACK Ultra Single lnb (IDLP-SINL40-ULTRA-OPP) | That is interesting. I'm using the super dark motor and apart from a metal logo on the box, it says nothing about metal gears in the spec. It seems fast and is very accurate but the noise!!! I can't use it after 10pm at night for fear of waking the neighbours. The larger the dish, the more noise it seems to make as the dish acts as a giant sound horn. It claims suitable for dish sizes up to 1.4m, I've only had it on a 88cm and 64cm dish. I've attached the booklet (pdf) with the spec. As you can see, not a titter of who makes it, where... nothin' | ||
| The Following User Says Thank You to thecaretaker For This Useful Post: | mick2me (21-09-2008) |
| | #14 | ||
| Member Join Date: 25-05-2008 Location: London
My System: Raven 60cm, fixed for Hispa, 30W, Fibo 90cm 53E - 61W (ex 16E - 28E), Channel Master 90cm 15W -28E, Technomate 5400, Echolink 777. For feeds: Vantage 221, Quali-TV 1080IRCI (4:2:2). Panasonic TH42PX80B Plasma TV. | What is known as the Darkmotor here, is the Powertech DG280. There are three models all together, so what in the UK is the "Superior Dark Motor" is the DG380 everywhere else. _http://www.powertech.tw/index.php?option=com_wrapper&Itemid=71 This is the US distribution: _http://www.sadoun.com/Sat/Products/PowerTech/Sadoun-DG380_HH_Motor.htm[/url] Plenty of spares sold there too and a realistic limit of 100cm. I think I heard somewhere that Powertech is owned by the UK distributor. | ||
| The Following User Says Thank You to joekir For This Useful Post: | HB13DISH (21-09-2008) |
| | #15 | |||
My System: 'Fortec Star Passion' (& a dead SL65) One of them big Woks on the outside, and a thingy that moves it about a bit. | The Manual contains some interesting stuff particularly trouble shooting solutions not included in my HH motor instructions. The sat table shows Astra 2 at 31E? | |||
| The best way to learn is from your mistakes... Sorry I made a mistake!... The best way to learn is from others mistakes. _www.Nottstalgia.com The Nottingham Forums Last edited by mick2me; 21-09-2008 at 06:15 AM. | ||||
| | #16 | ||
| Member Join Date: 08-01-2008 Location: Sweden
My System: WaveFrontier T-90 16LNB Cathing 18 birds 22w-33e- Laminas120cm Rotor - Dreambox7020 HDD 5 Spaun 420 1 SPAUN 410- 1 DM800 Laminas120cm- 1 DM800 T-90 In the satworld since 1991 | There are one more clone of this DiSEqC-motor, Clarke Tech. _http://www.clarke-tech.com/produkte?template=detail&entryid=22&lang= I have them both ,Golden Interstar and the Clarke Tech.Soon I will open them up to find out if there are any differ inside. The Golden Interstar GI 50-120 is a different model from the HH-100/120 that they also have at there homepage. I dont think the 50-120 is made by Stab, but the other models seems to be. Read somewhere that Moteck only make motors for theme self. all other is copies.I dont think thats true, i sent a mail to Moteck and Rita answered that they do make motors for other supplier under different name.So it seems that Moteck is a OEM This is the mail i got: 8/27/2008 Dear Hakan, We make OEM brand for our customers. PALM brand is one of them and is for our Netherlands customer. Best Regards, Rita Yu | ||
| | #17 | |||
This is what I was trying to find out for some time. Do they mention metal gear anywhere in their spec? | |||
| | #18 | ||
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | Hello! thanx for scaning the manual of darkmotor,i lost it in the meantime ![]() not every antenna,with the same size,has the same weight,so for e.g the triax 1,40m is very light,much lighter then gibertini 1,25 when you have strong winds,and moving a heavey dish,the fault of a diseqec motor comes much fuster,here in the maintains,i have no winds,that could be dangerous for a motor! moteck is not simular to darkmotor,i dont know maybe golde interstar has also his own oem manufactor,in an old dr dish isue,the also told,the the make there products alone,but i cant belive this,the buy most of the parts in taiwan! i have a motor it called bigsat range up to 75 east and its oem made by motech whats the technical reason about the noice of a motor i dont know,maybe a questions of the qality of components that are using! the egis for example is very quite,but moving much larger dishes then a cheap diseqec motor! | ||
| | #19 | ||
Not badly made, runs quietly. | ||
| The Following User Says Thank You to rolfw For This Useful Post: | HB13DISH (21-09-2008) |
| | #20 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Now your not going to be able to send that back Rolf Nice to see the workings of the motor. | ||
| | #21 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | I'll take that risk, but I tested it before taking the cover off. To be quite honest, it is hardly worth sending these cheap motors back if you have to do it by post, best to write it off to experience. | ||
| | #22 | |||
I just wanted to inform that Moteck really make motors to other brands,some says no they dont. The Clarke-Tech motor are spec with metalgears so when they arrive i will open them up to see whats inside. It looks that Golden Interstar ,Clarke-Tech,Darkmotor,Powetech are the same at the outside. | |||
| | #23 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Have started a thread in the Pictures of Members' systems section Hakon, so we can keep a permanent record, so when you post them here, I'll make a copy to that thread. | ||
| | #24 | ||
My System: WaveFrontier T-90 16LNB Cathing 18 birds 22w-33e- Laminas120cm Rotor - Dreambox7020 HDD 5 Spaun 420 1 SPAUN 410- 1 DM800 Laminas120cm- 1 DM800 T-90 In the satworld since 1991 | I did find some more info about these DiSEqC motors. It looks like there are different make of the OEM PowerTech. Dark grey = Metal gear, even the big maingear Silver = Plastic gear There are also manual or automatic zero backlash adjustment. _http://sadoun.com/Sat/Order/Motors/HH-Motors.htm _http://sadoun.com/Sat/Order/motor-comparison.pdf @rolfw The one you took picture off looks like a Moteck ? | ||
| | #25 | ||
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | Hello! does anyone ever try to replace the plastic gears in some motors including smr1224 jager,to metall gear version? would be a nice workshop | ||
| gears, metal, motors |
