coolsat 7000 + Dtv tri LNB 4 outputsInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 02-10-2008 Location: newport tennessee
My System: novice sat. user |
i was wondering if anyone here knew how to set up the coolsat with sat.dish with 3 lnb's and a built in disqu switch with 4 outputs. model number of the amp is : california amplifiers m/n : 150946 Tripple feed Multi-satellite LNB built in multi-switch w/ 4 outputs. Phase 3 18X20 dish Antenna i tried and only can get signal from the left (if looking at the sat dish) LNB. maybe a set up issue? thanks for your replies | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | You will need to go into the LNB menu and set it to diseq 1.1 and then choose an option of A, B or C for each satellite in the satellites menu. Unfortunately very few if any of our members use the Coolsat receivers, as they are not common this side of the pond. ![]() If you are not sure, take some screen photos of the setup menus and we may be able to tell where you are going wrong. | ||
| 7000, coolsat, dtv, lnb, outputs, tri |
