superjack diseqc motors - backlash adjustmentInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Design Engineer/Installer Join Date: 08-08-2007 Location: Central UK, E Cheshire ..near Jodrell
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions... |
Anyone up on these for backlash adjustment..? I think they have an auto mechanism.. not sure .. should retire it but it's still a very good motor. | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Is this similar to the Moteck SG2100, is there a little three screw tab on the underside of the motor with a warranty void if removed sticker on it? | ||
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions... | No Rolfw, the superjack's quite a one off - not a 2100 clone design or any clone.. this one's the one with the dial at the back that you can set to the correct position including offset, I think it's got auto focus too - stand in front of it and it will try to get past you to get a signal- that helps with backlash- (or maybe that is the auto backlash). Just doing a couple of mal Fortec(Turner) Motek 2100 clones now that have those adjusters on the front. They look the same outwardly but I don't think they are made as good as Motecks.... | ||
| adjustment, backlash, diseqc, motors, superjack |
