Automatic Sat Scanning,with diseqec motors compatible stbs?
Old 17-10-2008   #1
Turok's Avatar
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband!
Hello!
one special question!
awound 3 years ago,i was using one of the first xtreme sat receivers not the hornet,first modell,in kombination with staab hh motor,in the meantime i sold this receiver,and the staab is fault!
but on this comination,it was posible,to select all satelites,from 75 east to 45 west,and then you can go to bed,and the motor moves autmaticly to all satelites and scan them!
on the next day,you have all in your receiver list!
now i want to know,what diseqec usals stb,currencly would also suport this feature,the old stab hh 100 was no usals motor,when blindscan would be avalible,then,you would have nearly all transponders automaticly updated,i with vbox i could do the same,with my jager motor and the mesh antenna!
other technical questions,is it posible,to use one diseqec motor,over a swich,with 2 cables,and two stbs variantly?
or does every receiver,store his own go to x satellite in his "memory"?
Turok is offline   Reply With Quote
Old 17-10-2008   #2
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
Originally Posted by Turok View Post
Hello!
The Fortec Passion HD will search for new channels when left in standby overnight. I believe it works with USALS motors, although I don't have one, so I am restricted to searching one satellite at a time. No blind search though, just updates using the existing database.
Llew is offline   Reply With Quote
Old 17-10-2008   #3
rolfw's Avatar
Real name: Rolf
The Technomate series can use automatic scan of registered satellites as well, although I have never actually carried this out as I don't use one. I believe the Dreambox is supposed to do it, but have found that it doesn't work well with USALS/GoToX at the best of times, so unlikely it would work.
Not sure about your DiseqC motor question, but I would imagine that the motor would become confused, you would need to send it to reference/reset every time you switched receivers.
Rolf
Old 17-10-2008   #4
Robbo's Avatar
Real name: Mark
It should be alright with USALS /Goto X, as the receiver calculates where to send the dish to, and just sends a Goto X command to the motor.
I just did an experiment with a Motecksg2100a that I have on the bench right now:-
Sent motor to 16 E, turned off reciver, unplugged the coax to the motor,
turned receiver back on, sent motor to 15W, turned off receiver, plugged coax back in, turned on receiver and sent motor to 15W, it went there OK.
Old 17-10-2008   #5
satelliteman's Avatar
Real name: Paul
Auto navigation option on the TM series works well but takes nearly a day to complete
satelliteman.
An Installers Choice
Follow us on
Old 17-10-2008   #6
acezon's Avatar
My System: DreamBox 600s, Darkbox 2008, Liberty FTA reciever, Humax Foxsat HD, Thomson Sky+, 3 fixed dishes, 60cm for 13E + 19E, 80 cm motorised,Zone 1 sky+, BtVision and My 37" baby.
My darkbox 08 has said search feature also blind scan,
acezon is offline   Reply With Quote
Old 17-10-2008   #7
Turok's Avatar
what one day to complete the search,sounds amazing
never have technomate,so i dont know this important fact!
on extreme stb it only takes around 30-45 minutes!
the kvr 1000 search is much slower!
fastest search in blindscan is smart mx 04 only 3 minutes for the complete satelite!
staab hh 100 was non usals motor!
Old 17-10-2008   #8
Real name: Paul
Auto navigation and blind search on the TM for 20 or so satellite positions will take the time stated above.
satelliteman.
Follow us on
automatic, compatible, diseqec, motors, sat, scanning, stbs
[IMG] code is Off
