Technisat Multytenne Dish Location
Old 28-10-2008   #1
My System: Fortecstar Passion HD+
Hi -I have just ditched Sky and am going my own way - I would like to try out this dish looks eaasy for a self install - it says it works as far north as Birmingham anybody got one working further north I live in Stoke about 50 miles north of Birmingham
If not any suggestions for a muklti sat LNB
On another point I can get both Astra 28.2 and Astra 19 Sats on my old sky dish is this usual?
REgards
Red
REDMAXCAT is offline   Reply With Quote
Old 28-10-2008   #2
satelliteman's Avatar
Real name: Paul
Also consider a straight forward DiSEqC motor system (80cm dish with H-H motor).
More choice, more satellites
SM
satelliteman.
An Installers Choice
Follow us on
The Following User Says Thank You to satelliteman For This Useful Post:
REDMAXCAT (29-10-2008)
Old 28-10-2008   #3
Robbo's Avatar
Real name: Mark
A Triax TD88, with a Multi-block works quite well, for 13E,19E,23.5E and 28E.
Or for 16E, the TD110.
The Following User Says Thank You to Robbo For This Useful Post:
Old 29-10-2008   #4
Hi - I have considered this but have a restricted location for the dish its against a east facing wall - could the motor arc be limited?
Cheers
Old 29-10-2008   #5
Hi - If I can't fit the motor - I will go for this option - when looking they have clear dishes of the same size would these work as well?
Cheers
Old 29-10-2008   #6
Real name: Paul
Cheers
yes, as long as you can see the satellites, the dish arc can be limited to just S East.
Take a look at dishpointer.com
satelliteman.
Follow us on
Old 29-10-2008   #7
Robbo's Avatar
Real name: Mark
Cheers
I have never used a clear dish, but in theory yes, I believe that an adapter can be purchased to go from a Traix multi-block for example to a clear dish. I have also used on my own system a Triax Multiblock on an Orbital 1m dish, but I don't have it perfected as yet.
Old 23-11-2008   #8
My System: Dreambox 500, WaveFrontier T90, Nokia MM9500
Lightbulb
Clear disks have another small disadvantage.
Due to their shiny surface, they reflect sunrays, which can melt the LNB/holder.
This can occur on certain days, when the sun is exactly posioned behind the satellite where the dish is pointed at.
_http://www.satellite-calculations.com/SUNcalc/SUNcalc.htm
SimonleBon is offline   Reply With Quote
dish, location, multytenne, technisat
[IMG] code is Off
