04-11-2008
#3 |
| cerca trova...
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300.
Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
| I had the same alignment problem with my Invacom C120 and SMW feedhorn, only four bolts would fit. It's been up and working fine for a couple of years. I checked inside the LNB just this weekend in fact when doing a comparison with an Inverto, and it's perfectly OK. As long as you have a good seal with the O-ring, you should have no problem.
Llew |
Celebrating Ten Years Of The Forum As A Founder Member |
