Noob needs help getting Astra 28.2 in Belgium
Old 04-11-2008   #1
My System: Metronic 80cms dish with monoblock lnb I T Gate (tgs 200) Receiver
Hey guys, I was wondering if someone could give me some advice on setting up a system in Belgium to receive the UK channels on Astra 28.2. My mother's been living here for a while and recently bought a system, hoping that I could set it up for her. The system includes :
80cm Metronic dish
Twin mono bloc lnb (DiSEq 1.0)
TGS200 receiver
I've set the dish up according to the info I got from dishpointer.com (n.b. at present I am only interested in receiving Astra 28.2, maybe I'll try something else later).
Anyway, after much toil, I haven't managed to get a single signal lock, so I was wondering if someone could help me out and tell me if I'm doing something wrong. Here are some pics:
Btw, this is my first install, hahaha, hope it won't be my last
Noob needs help getting Astra 28.2 in Belgium-th_01350_rear_view_122_61lo-jpg   Noob needs help getting Astra 28.2 in Belgium-th_01337_front_view_122_656lo-jpg   Noob needs help getting Astra 28.2 in Belgium-th_01332_dishpointer_122_182lo-jpg
Last edited by Robbo; 04-11-2008 at 01:53 PM. Reason: Uploaded pictures rather than link to them.
Johnnie_Walker is offline   Reply With Quote
Old 04-11-2008   #2
rolfw's Avatar
Real name: Rolf
Can't really tell very much from the pictures, as they are too small.
You need to make sure that your connections are good, then the easiest way is to take a portable TV outside and watch the signal meter on the screen whilst you slowly pan the dish.
How is the pole mounted?
Also a monobloc is not ideal for single satellite setup, identify which one is which by putting your hand over the end and seeing if the signal changes, then mount that side in the central clamp.
Rolf
Old 04-11-2008   #3
GreenmanBelg's Avatar
My System: 1 x CM 1.2m matching C120 feedhorn and Invacom 0.3db twin output LNB.50 degrees East to 42 degrees West.1 x CM 1.2m AZ/EL mount matching C120 feedhorn and twin output Invacom 0.3db Humax VACI 5300 Old Panasonic Digibox with IRL $ky sub. Coship FTA
Question
Where are you in Belgium?
GreenmanBelg is offline   Reply With Quote
Old 10-11-2008   #4
hey, thanks for the replies. Sorry I took so long getting back to you, been busy tearing my hair out :P. I am near Mons (Bergen) in Wallonia.
I have been using the info I got from dishpointer but I can't get a lock on a satellite signal (is dishpointer accurate?).
I keep moving the dish around and then doing an automatic transponder scan but it's always the same (nothing, lol)
Should I be thinking about getting a different lnb to receive astra 2?
Anyway here are those pics again, hope they are a bit clearer :P
thanks for your help
Noob needs help getting Astra 28.2 in Belgium-dishpointerinfo-jpg   Noob needs help getting Astra 28.2 in Belgium-front-jpg   Noob needs help getting Astra 28.2 in Belgium-rear-jpg
Old 10-11-2008   #5
satelliteman's Avatar
Real name: Paul
I'd see dishpointer.com for rough settings and use a single LNb for setting up the dish.
satelliteman.
An Installers Choice
Follow us on
Old 10-11-2008   #6
Robbo's Avatar
Real name: Mark
I agree, a 6 deg' monoblock is pretty pointless for 28E.
Also, focus on a single transponder 11954H 27500 2/3 for example. Monitor the sig quality on that while adjusting the dish.
The dish also looks like it is the middle of a field
I assume that you not trying to use a cable that is far too long when trying to adjust.
Old 10-11-2008   #7
JTA
JTA's Avatar
My System: Dreambox with PLi-Emerald 1.09 image, Matrix revolution CAS, newcamd emu, movable dish 0.85 m, very happy indeed
stop with tearing your hairs out and start buying a satfinder. This only costs 15 euros but it will help you to accurately align your dish. As you've found out, it's no good just pointing it somewhat in the direction where it might find something :-)
receiving Astra2 near Mons should be no problem, as it's one of the stronger satellites, you should even get the 2D without any problems.
IF your dish is aligned correctly. Use a satfinder !
JTA is offline   Reply With Quote
Old 10-11-2008   #8
I'm over near Hasselt if you were closer I'd drop in and help.
Thats a good point from Robbo do you have TV and sat receiver out with you in the garden? thats really the only way.
Let us know how you get on maybe tomorrow as its a free day in Belgium.
Regards JD Belgium.
Old 10-11-2008   #9
Robbo's Avatar
Real name: Mark
I gave up on the cheapo satfinders long ago, but some people still manage with them.
I use my TM receiver with a 7 inch (17.5 cm to you Europeans) LCD panel, or a Lacuna meter, both give me accurate and easy dish adjustment.
Old 15-11-2008   #10
Thx for the advice guys. I'll try and have a fiddle about with it at the weekend.
BTW, if I buy a cheapo single lnb from the local DIY store will that work okay with my dish?
Oh and I can see why this is such a popular hobby. The frustration turning to joy when you succeed must be equivalent to taking cocaine or something
282, astra, belgium, noob
[IMG] code is Off
