Max length of cable?
Old 12-11-2008   #1
My System: (trying to setup)1m motorised dish, tm5400 CI+ super
What the max length of cable from sattelite dish to tv?
From the bottom of my garden to tv will be about 100 - 110ft
The cable i have currently is T R Sat RG6U coaxial cable 75ohm
Will that be ok, or should i get something better?
Regards
Rob
rob_brum is offline   Reply With Quote
Old 12-11-2008   #2
satelliteman's Avatar
Real name: Paul
I'd go for benchmarked cabling such as Tx100, Wf100.........
Using the above cable, the losses are known (10dB @ 2Ghz).
RG6 will work but not the best for the job and may have more loss at the higher end of frequencies.
SM
satelliteman.
An Installers Choice
Follow us on
Old 12-11-2008   #3
SM
Are they both the same or is wf100 better?
Cheers
Rib
Old 12-11-2008   #4
Real name: Paul
correct, they are just two listed as an example.
check with site sponsors; I'm sure they can supply.
See also: Best Coax Cable?
Post #13 in particular.
SM
satelliteman.
Follow us on
Old 12-11-2008   #5
Robbo's Avatar
Real name: Mark
If you have the RG6 cable already, I would say try it, see how it performs.
If is doesn't work very well, pay out for better quality stuff.
I would never buy the cheap stuff in the first place though.
screwfix do pf100, for about £32 a reel by the way.
cable, length, max
[IMG] code is Off
