What satellites with a 2.4m? | |
| Member Join Date: 15-04-2005 Location: Midlands
My System: 1m Dish Motorised, Technomate 5500CI Super, Dragon, Conax, DigitAlb, and ART. |
I have a 1m dish now but if I got a 2.4m dish, what extra satellites could I pick up in the UK? I get about 18 satellites now with my current dish. Can someone list me a few satellites so I could see if i'd benefit from a dish this size? | ||
| Regular Member Join Date: 30-06-2007 Location: Brussels Belgium
My System: DB7000S HDD USB2GB; 2CM120+Norsat4106Afor HH&7707AforVH on 7°W; Triax 2X110, 1X88 and 1X64. LNBFs: 2BESTQ, 2InvacomQ; 3XAlps, 2Inverto(1Q), 3XBEST; Switches and M/S; Centauri P-168. 30w, 8w, 5w , 1w, 5e, 9e, 16e, 23e, 28e; 13E, 19E; 26E | Among others, you could get Nilesat horizontals at 7°W, Atlantic Bird 4 at 7.2°W, all Badr's transponders on 26°E and Eurobird at 25.5°E. | ||
| | #4 | |||
| Regular Member Join Date: 04-09-2008 Location: 40kms NE of Antwerp,Belgium.
My System: 1 x CM 1.2m matching C120 feedhorn and Invacom 0.3db twin output LNB.50 degrees East to 42 degrees West.1 x CM 1.2m AZ/EL mount matching C120 feedhorn and twin output Invacom 0.3db Humax VACI 5300 Old Panasonic Digibox with IRL $ky sub. Coship FTA | Had you decided on which dish you'd get? do have an ideal place to install it? Let us know. | |||
| Regards JD Belgium. | ||||
| | #6 | ||
| Specialist Contributor Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | Hello! in Belgum,there is a high difrence,,depent on your location,what dish size ins needed to catch H only 30 km difrents location,in belgum,a friend told me,from belgum,could make very big difrence, 1,80 m are okay,but 30 km going north 2,40m needed in belgum needed for same signal,because,its out of footprint rectption at the end,i would say! | ||
| | #7 | |||
| Design Engineer/Installer Join Date: 08-08-2007 Location: Central UK, E Cheshire ..near Jodrell
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions... | On a 1m there you should expect to get .. 45 42 40.5 39 36 33 28.2(&5) 26* 23.5 21.6 19.2 16 13 10 9 7 5 EAST 45 43 37.5 34.5 31.5 30 27.5 24.5 22 18 15 12.5 11 8 7** 5 1 WEST * including MBC's TP but not BADR 6 ** Only the strong verticals such as City 7 / Dubai One etc... *** some weaker beams/ TPs will be missing on some satellites and some satellites like 27.5w only have feeds checK out the strongest signals list elsewhere on this forum (listed above this subsection) for the whole arc (bit out of date now but most are OK) and lyngsat.com (or Flysat or Kingofsats) for detailed lists of those satellites... also check the signal (footprint) maps (at the right side) to see what signals are transmitted to the UK (ie: easy to get) and which are not (not so easy to impossible to get) you might actually get about 90% of satellites/ channels with a 1m ... the bigger dishes are just for a few difficult sats as already listed (7w etc..) you can actually get almost all those sats on a z1 Sky dish.. minus a few tps/beams you can also get further east or west and you may find some satellites missing in the arc due to local obstacles like trees/ chimneys... | |||
| | #8 | |||
Of course there is a small consideration to be give to such a thing as planning permission ![]() | |||
| | #9 | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorks, uk
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | i don't think you need planning permisson if the dish is not fixed to the ground as i believe rd100 had his 1.8m dish on a pallet or something with a dish 2.4m you could use it for feeds more as you would have the size for getting them with a margin for weak signals if your wanting a larger dish then go to something like 1.5m etc, if you need to boost signal strength on a particular satellite you receive now | ||
| 24m, satellites |
