Triax dish & motor kitInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 15-11-2008 Location: Dartford Kent
My System: Comag sl1000hd 2ci Triax 60 cm 4 LNB 16E/13E/19.2E/28.2E |
Hello Just trying to gauge opinion, i saw a triax 80cm dish + tecnomate diseq motor & wall mount for around Ł130 on satelitte superstore..is this about right price wise ?? and is this kit any good.. I am tring to recieve hotbird 13e eutelsat 16e & astra 28e so figured this would be betterer than one dish with 3 lnb,sFairly new to this game so trying to temper my enthusiasm til i know whats what. Currently got an old sky dish with an eliptical 65 cm dish if i swivel it around would this pick up hotbird as well ??. Thanks in advance | ||
Indeed it would just swivel it round 15 degrees West, you may need to elevate the dish a tad to get it spot on if you have easy access as Hotbird is slightly higher on your arc than 28.2 East. Try the forum sponsors for your dish and motor http://www.satellites.co.uk/index.php?page=sponsors help us to help you | ||
| | #3 | |||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s |
For execellent results on W2 16e, a FR Penta 85cm will perform out standing on a motor. SM | |||
My System: Comag sl1000hd 2ci Triax 60 cm 4 LNB 16E/13E/19.2E/28.2E | Thanks for earlier replies, So i had a fiddle ![]() with my dish and can only get astra 19,2 & 28.2 there is a group of trees with a gap big enough for astra but nothing else (presumbly) ![]() Does this mean i have to get a biger dish or mount it higher or both ? ![]() I know its kinda hard without seeing the actual site but the trees are at the end of the100ft garden and they are at least 100ft tall at the mo they are leafless Detection method is a bit crude ie use the signal meter and tone built in to the reciever select hotbird and twiddle the dish whilst listening via a set of cordles phones ![]() basic i know but works ok for astra. | ||
| | #5 | ||
My System: Comag sl1000hd 2ci Triax 60 cm 4 LNB 16E/13E/19.2E/28.2E | Hooray so i am back again after a small break and now have.... A Comag SL1000HD reciever- Triax 60cm dish with 4 lnb setup and a 4 way DISEQ switch. Original plan was 16e/13e/19.2e/28.2 both Astras are fine as is Hotbird but Eutlesat is just to close to Hotbird on the LNB, which means (i guess) smaller narrow focus lnb,s to sit closer together. The dish is centred on 19.2 and the Hotbird LNB currently gets some (but not all) Eutlesat channels. I also now need to get Atlantic Bird 3.0w on the same dish is this a sat to far ???. | ||
| | #6 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Do you mean Atlantic bird 3 at 5W? You might be able to do it, but 24 degrees off centre may be a little optimistic. | ||
| | #7 | ||
My System: Comag sl1000hd 2ci Triax 60 cm 4 LNB 16E/13E/19.2E/28.2E | | ||
| | #8 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Well either that, or a second dish, a Sky minidish with doctored LNB (need to reverse the skew angle) would do it. | ||
| | #9 | |||
| Toute Ronde Bon Oeuf Real name: Gordon Join Date: 29-05-2009 Location: North Yorks Moors
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. |
| | #10 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Yep actually you are right, was thinking of the minidish installations I'd done for Hispasat. | ||
| | #11 | ||
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | Funny you should mention Hispasat, as my Tree problems have stopped me getting this - EVER. But I have a cunning plan brewing ................. One not involving Chain Saws | ||
| | #12 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | | ||
| | #13 | ||
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | | ||
| dish, kit, motor, triax |
