LNB strength | |
| Member Join Date: 20-10-2006 Location: Fylde Coast in West Lancashire
My System: WinXP/Firefox 85cm Transparent dish and 3 dual LNB's 13,19,28 One diseqc to Sky Star 2, and a diseqc to TM1500. Plus a loop from the TM1500 to a Pace MSS100 analog sat receiver. |
When using a dual output lnb does the inner or outer have a stronger signal than the other. My setup is complicated, 85cm dish with 3 dual output lnb's. The 3 outers go to a diseqc and the 3 inners to another diseqc. One cable goes thru the wall to SkyStar2, the PC and DVB Dream (with Prog DVB as an alternative if needed). The other cable goes round the house to the backroom downstairs, to a TM 1500 and the TV. I can't see if its the inner or outer which goes thru the wall to the PC but the TM 1500 with the long cable run shows strength at around 75, the DVB Dream (and Prog DVB) on the short cable run shows Quality around 48 to 50 and Level around 44 to 48. Normally its upstairs live or downstairs live, but today I've run a check with them both live and got the same results. All this is because on the Pc I constantly get 'Timeout - This PID is empty. Rescan' and doing several rescans a day is sending me bonkers. I would have expected the lower strength to be on the longer cable run. | ||
| Regular Member Join Date: 08-02-2005 Location: Lot, Dordogne, Correze border.
My System: FTE Max, Skystar2.3 and Skystar2.6, 2.2m Kinhuge Dish with Inverto LNB and Invacom ADF-120 feedhorn. Pace 1.3.25 and 80cm for Sky. | The quality (and signal levels) are not comparative between the two receivers. You might find that the TM is more sensitive (to weak signals). You might also find that one diseqc switch is lossier than the other, and one LNB OP might be slightly higher. I would take the TM upstairs to see how it performs, this will identify whether it's the Rx that is more sensitive or if you are losing signal to your Skystar. | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | | ||
| | #4 | |||
I ran the TM1500 on the upstairs incoming cable. I got a good signal on 19E of 75 (same as downstairs) but zilch on 13E or 28E. It doesnt show an error message. When I put it back into SkyStar2 I got the same error message in vPlug on all 3 Timeout- This PID is empty. Rescan Perhaps I've disturbed the diseqc box. I bought the 3 lnb setup and asked the installer to install my existing LNB but I was greedy. It was too heavy for the arm which swung around in the wind. I uncoupled the 4th LNB and sliced off the cables before they went into the diseqc. This summer I've removed the cable stubs and the Fconnectors but I didnt have the proper tape so I left the plug bare and just put the weatherproof cover back on and ziptied it. The other 3 in and the single out are still properly sealed. Did I do the right thing, and could this be the reason for the constant need to rescan ? | |||
| | #5 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | The only way to find out is to gradually work your way back through the system, until you get to the LNBs, testing the signal along the way. You can test the other LNB outputs by swapping the outputs, and see if the upstairs still works Ok, and that the downstairs doesn't any more. | ||
| | #6 | ||
My System: WinXP/Firefox 85cm Transparent dish and 3 dual LNB's 13,19,28 One diseqc to Sky Star 2, and a diseqc to TM1500. Plus a loop from the TM1500 to a Pace MSS100 analog sat receiver. | Oh Yes! Thanks Robbo I'll save that task for a warmer day. | ||
| lnb, strength |
