39E hellas sat low intensityInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 03-08-2008 Location: UK
My System: sky tv Technomate 3200d+ 80 Cm dish Digipower motor DisEQC H-H motor SG-2100 |
Hi I have successfully set up my Technomate 3200+d box with an 80cm motorised setup, i can receive 1W 5E 13E 19.2E 28.2E The motor will not go to 39E when i use the "goto position" in the menu, so i when i manually try to turn the motor via the set-top box to 39E the light underneath the motor goes red "low intensity" Is this a problem because its off the arc or there is an obstruction?. All all sats have a strength and signal at around 80% 28.8 has very good signal quality. Thanks Gray | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Regardless of signal being received, the motor should still turn round to 60 degress from zero with USALS. Try resetting the motor. Go to DiSEqC 1.2 mode > Under motor menu control > Reset system. | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | I which case using DISEqC 1.2 you'll need to check Limits. Reset is a reset. SM | ||
| | #5 | ||
My System: sky tv Technomate 3200d+ 80 Cm dish Digipower motor DisEQC H-H motor SG-2100 | Hi I have checked the motor and there is noting stopping it on hardware limits but no where in the technomate menus can i find a rest motor option I have tried deleting limts in the software but the strengh still stays at 73% and 5 quality. Could some please tell me where the menu is to rest the motor. | ||
| | #6 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | It is as SMM said. Under Motorized Setting Next to DiSEqC Motor select 1.2 intsead of USALS Then go down to Motor Control, press OK and you will see the Reset system option. | ||
| | #7 | ||
| Member Join Date: 24-03-2008 Location: Lancashire
My System: Technomate 3100d 90cm FortecStar dish FortecStar HH120 motor powered by UsalS FSku-VN 0.2db LNB 30w>53e FortecStar mercury II fixed at 19east FREESAT with card. EuroVox ex5000pvr | If the motor was second hand the last owner may have taken the cylinder off and adjusted it so it goes no further than 28.2east but this means the motor should go to 91.8west, not that any sat will work that far west. | ||
| | #8 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Reset motor on the receiver menu first. If still not working then: > Hard reset on the motor it'self - (small reset hole on the motor body) > Check physical limits by checking the sliders on the motor - (motor shaft will have to be taken off to see this). Should be preset to around 60 degs. | ||
| | #9 | |||
My System: sky tv Technomate 3200d+ 80 Cm dish Digipower motor DisEQC H-H motor SG-2100 | Regards | |||
| | #10 | |||
| | #11 | ||
That is how they come as default out the box, yes. Easiest way to check is to try another receiver on USALS. | ||
| 39e, hellas, intensity, low, sat |
