C-band : Higher conversion rate or lower Kelvin ?Information exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Regular Member Join Date: 14-03-2007 Location: 25'40'32S. 28'14'5E
My System: Metabox 3 ; DM500s 0.6m Elsat Lnb Ku-band 1.0m.Dual KU Band LNB 3.1m K-Tronix Mesh Gospell C-band + Kombined KU LNB 4 way Diseq Switch |
Morning guys!(Dont know if we have ladies here?) I have searched,but get conflicting answers.... My Cband LNB is on the way out,it acts up every now and then. Iam looking at a new Cband Lnb,just a single output one. Which one the two is more important when looking for a new one ?(Or is it a combination?Or something completely different?) ![]() 1)The conversion Db of it? 2)The noise temp ? I currently have : MTI AC13-2CV with the specs : Frequency Range H: 950 - 1450MHz V: 1500 - 2000MHz Connector Type 75Ω Female Connector VSWR 2.5:1 (max) Local Oscillator Frequency H: 5.150GHz V: 5.7GHz Frequency Stability ±1MHz (max) @ room temp. ±2.5MHz (max) @ -40°C ~ +60°C Frequency Phase Noise -75dBc/Hz (typ) @ 1kHz @ room temp -93dBc/Hz (typ) @ 10kHz @ room temp -105dBc/Hz (typ) @ 100kHz @ room temp Conversion Performance at Room Temp Conversion Gain 60dB (min) Gain Flatness ±5dB (max) over operating band ±1.5dB (max) / 36MHz Noise Temperature 25°K(max) Image Rejection 40dB (min) Cross Polarisation 20dB (typ) Thanks for the help! ![]() Karis | ||
| We will take over the world-One Sat reception at a time! | |||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Low noise wins over gain, whether C or ku band LNBs - you can increase gain with in-line amplifiers, but you can't lower the noise level. Llew | ||
| The Following User Says Thank You to Llew For This Useful Post: | karism (05-12-2008) |
My System: Metabox 3 ; DM500s 0.6m Elsat Lnb Ku-band 1.0m.Dual KU Band LNB 3.1m K-Tronix Mesh Gospell C-band + Kombined KU LNB 4 way Diseq Switch | Thanks for the reply! Great stuff Should i be concerned that a 13K LNB has a lower conversion gain than my MTI ( 60db min ) some of them have a 55db min conversion ? | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Don't think 5db is going to make much difference. Don't have aany experience of C-band stuff, but whatever terms are used, the principle should be the same. Llew | ||
| | #5 | ||
| Specialist Contributor Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | Hello Karism! look in the topic cband twin lnb,here i have explained your question! | ||
| cband, conversion, higher, kelvin, lower, rate |
