Octo lnb with multiswitchInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | One of these should do it:- _http://www.vision-products.co.uk/pdf/Vision%20Data%20Sheet%20(V75-508_V75-512_V75-516).pdf | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | They will work with a quad, they should work with an octo with the other 4 outputs going to waste. | ||
| | #5 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Any Q2 Multiswitch will work it of course only requires four feeds. | ||
| | #7 | ||
| Member Join Date: 10-12-2008 Location: Wales
My System: ? | ta for the info, but the setup is there are 6 feeds from the dish on a new build all cables hidden, 2 for sky+ going to the living room and 4 going back to the basement for a multiswitch to feed 6 points around the house for sky and freesat, is there any other way of doing this? Cheers | ||
| | #8 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | A switch that supports Q2 will select the required band from a universal ports of the Quad or Octo LNb. | ||
| lnb, multiswitch, octo |
