4x1 DiSEqC switch setup DM500Information exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 11-12-2008 Location: LONDON
My System: DM500S / WAVE FRONTIER T90 / DBOX 2 / P4 3.OGHZ 2TB | I am having real trouble setting up a Wave Frontier T90 dish, Global UK Communications 4x1 Switch and Dreambox DM500s with Gemini Image LNB’s at 13, 19, 23 and 28 all with good signals Switch Lnb 1 – 13 Lnb2 – 19 Lnb3 – 23 Lnb4 – 28 RX – DM500 I just cannot get the receiver to switch to any LNB ??? any HELP would be appreciated. | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Hi, it might be a good idea to explian what you have tried so far. | ||
My System: DM500S / WAVE FRONTIER T90 / DBOX 2 / P4 3.OGHZ 2TB | From main menu setting then service searching sat config. Non-stnd user defined config my 4 chosen sat's created all other deleted in lnb config for each sat LNB0 then LNB1 for next sat etc LOF/L 09750 LOF/H 10600 (universal) Threshold 11700 Unticked increase voltage Next page Toneburst None DisEqC Mode V1.0 DisEqC Parameter A/A Sequence repeat unticked Fast DiSEqC unticked then for next LNB1 DiSeqC Parameter A/B and so on for remaining... Also tried DiSEqc Mode V1.1 as above with DiSEqc Repeats One (Only have a 10 Meter run) and none Uncommitted Switch None and unit 1 Only have Swap Commands ticked | ||
| | #5 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | I have used the Diseqc1.0 facility on a TM9100 and the setup sounds similar. However, not sure why you have gone into non-standard configuration. A 4x1 diseqc switch should be a standard option, along the the lines of 'Multisat via Diseqc switch" The setup in there is far easier as I recall. Just a matter of setting the 4 LNB names and then setting which switch position is to be used for them, i.e AA,AB,BA,BB. | ||
| | #6 | |||
| | #7 | ||
| Member Join Date: 26-10-2005 Location: Cheshire, UK
My System: Dreambox 500S, Orbital 80cm Dish, Technomate TM-2300 Motor. |
I am currently having problems setting up a 4x1 Disecq v2.0 switch (ASAT) to work with my Dreambox 500S: My setup is as follows: I have a motorised satellite dish which will be used to access all satellites other than 28E. I have a fixed satellite dish which will be pointed solely at 28E. Please could someone tell me the correct settings to enter into my Dreambox 500S to get the above setup working correctly. Should the motorised dish be connected to SAT1 on the Disecq switch? Should the fixed satellite dish be connected to SAT2 on the Disecq switch? Or Vice versa? Should the motorised satellite dish be setup using Disecq 1.2 and the fixed dish using Disecq 1.0? If not what should the Dreambox settings be? Should the repeat option be ticked? Should the LNB settings for the motorised satellites all be the same and the fixed satellite different under satellite configuration? Are there any issues using a Disecq (version 2) 4x1 switch with a Dreambox 500S using the above satellite setup? Any help would be greatly appreciated as I have struggled with this for ages and want to get it working. | ||
| | #8 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | From memory, the switch should go after the motor , port A for the motorised LNB and port B for the second dish... | ||
| 4x1, diseqc, dm500, setup, switch |
