Multi Lnb & motorised setup
Old 28-12-2008   #1
My System: Dreambox DM7025 Humax 5400 Echostar 3000IP
I am looking for a way to have multiple lnb's on a motorised setup , I already have a Jaeger HQ 1224 SMR together with an adapter plate that is probably for a channel master 1.2 m dish but have not found any info on multiple lnb's used with this dish, has anyone done this ?
Another option may be a Gibertini 1.2 / 1.5 dish that I know supports multi lnb's but can it be fitted to a Jaeger HQ 1224 SMR ?
Or is there an alternative option ?
Any help appreciated
Smurf
smurf5599 is offline   Reply With Quote
Old 28-12-2008   #2
dorsetbob's Avatar
Real name: Bob
My System: 60cm SKY Dish with PACE Digital Digibox, 90cm PHILIPS (Fibo clone) Gregorian (started with all original features). MTI AP8-TW LNB. TECHNOMATE 5500 CIP PLUS Receiver, STRONG 4375(as Backup)
Hi Smurf
From what I have read (although I maybe wrong,but I'm sure someone will correct me)multiple lnb's on a motorised dish just isn't feasible.
Multiples on a fixed dish is.
What satellites are you looking to get?and what are you looking to watch?
Bob
dorsetbob is offline   Reply With Quote
Old 28-12-2008   #3
Design Engineer/Installer
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions...
Why do you want to use multiple lnbs on a motorised dish.. is there a particular reason.
pedro2000uk is offline   Reply With Quote
Old 28-12-2008   #4
guest
Posts: n/a
Nearest to this I ever achieved was a 6 deg Monoblock on an 80cm Motorised.
The reason was I didn't have a spare single Universal LNB at the time, so I shoved the Monoblock on.
It did work with both Motor Control and LNB selection available simultaneously, but only with an ancient Fortec Star Lifetime Classic Rx.
When I donated that Rx to the Wife, I found that no other Box in my stack would allow simultaneously Motor Control and LNB selection.
The only advantage of the system was that I set 28E to Port B and everything else to Port A which meant I could get 28E by setting its position as 22E, thus reducing traverse time between it and eg 19E, 13E.
I didn't plan it that way - it just happened!
Old 28-12-2008   #5
Hi, thanks for the reply's ..
I'm really trying to have a setup that for normal viewing I'm just switching between lnb's with the dish parked in a set position Hotbird for example. Then when I want to have a nose at other satellites I can switch to the main lnb and go to whatever satellite I want , when I've finished I just park the dish back on hotbird.
I figured once it's setup it shouldn't be too much trouble and I'll have the best of both worlds , in theory I don't see too much of a problem.
( Probably aiming for Thor to Astra 2 for the multi lnb's )
My first hurdle is knowing if I should go with the channel master or gibertini.
Regards
Smurf
Last edited by smurf5599; 28-12-2008 at 02:11 PM. Reason: Forgot to add Satellites.
Old 28-12-2008   #6
I think that's an excellent system... saves wear and tear on the motor too.... just getting an stb to see a motor & a switch without getting confused... and making sure some LNBs don't cast a shadow. You could do the same with a second dish having the multi's on it. You can lose a bit on most diseqc switches remember if you have any weak satellites you like on the arc.
Old 28-12-2008   #7
GreenmanBelg's Avatar
My System: 1 x CM 1.2m matching C120 feedhorn and Invacom 0.3db twin output LNB.50 degrees East to 42 degrees West.1 x CM 1.2m AZ/EL mount matching C120 feedhorn and twin output Invacom 0.3db Humax VACI 5300 Old Panasonic Digibox with IRL $ky sub. Coship FTA
Question
Do you mean something like this?
_http://www.satellites.co.uk/satellite/dish-setup-single-sat-multi-sat-motorised-systems/140632-cm-1-2m-multifeed.html
Regards JD Belgium.
GreenmanBelg is offline   Reply With Quote
Old 28-12-2008   #8
Hi GreenmanBelg,
Thats the sort of thing although it appears to be restricted to 2 additional lnb's , I'm beginning to think I may need to go for a Gibertini dish with their multi feed assembly rather than a channel master.
Or perhaps I can make one myself
Regards
Smurf
Old 28-12-2008   #9
Robbo's Avatar
Real name: Mark
A motorised dish is no more restricted on the number of LNBs that you can have on it, than a fixed dish. I've bunged a few extra on my Triax for a laugh. I initially made brackets from copper tubing, and later used a multibracket (like the Gibertini). It was good for when the dish was parked at 19E, with the other LNBs on the bracket available without having to move it.
I now have two dishes, one motorised and one multi-LNB, even better.
Robbo is online now   Reply With Quote
Old 29-12-2008   #10
dorsetbob's Avatar
Real name: Bob
OK I was wrong !
Thanks for the correct info guys.
But I still dont understand why you would want to put multiple lnb's on a dish that moves.
Is it that you can channel hop more quickly?
Bob
Old 29-12-2008   #11
Robbo's Avatar
Real name: Mark
Bob
Apart from less wear on the motor, it's the only reason i can think of.
I had mine set up so that when I was on 19E, I could also flick to 13E,23.5E and 28E, without waiting for the motor to move. 7W and 1W, is probably a better combination now though.
Old 11-10-2009   #12
My System: Comag sl1000hd 2ci Triax 60 cm 4 LNB 16E/13E/19.2E/28.2E
HMMMMM i might be doing something like this soon
got 4 lnbs on a Triax 80 cm for 16e/13e/19.2e/28.2e
all plumbed in to a 4 way Diseq switch, 16e reception
is rubbish (to close to 13e) and i also want to get Atlantic
3w........SO if i get a Diseq motor can i still use it with the
4 way switch ??? I am thinking lnb 2 -13/ 3-19.2 /4-28.2 via switch as
normal and lnb 1 switch to motor and then to lnb 1
Will this work ??? or will my dish spin round like a helicopter
Any coments please
Rusty Dish is offline   Reply With Quote
Old 11-10-2009   #13
satelliteman's Avatar
Real name: Paul
A Td88cm for those four would be better, also there is a modification to the offset bracket for improved reception of 16e. DiSEqC switch will need to be installed between the motor and LNb.
satelliteman.
An Installers Choice
Follow us on
Old 11-10-2009   #14
Robbo's Avatar
Real name: Mark
Yep, 16e, needs to be right on the focus, as if the multiblock was not installed.
Apart from that, if you have the TD78, it is a bit too small for 16e, as the dish is only 70cm wide.
Putting the switch between the motor and the LNB as SM says should work, and if the receiver allows, you can set the motor position for the offset LNBs to be the same as the focal one, that way the dish will be in the right place for the offset, as well as the focal.
Old 4 Weeks Ago   #15
Thanks for help and replies, i now have a diseq motor
setup with single lnb and can go from 16e all the way to 8w (so far)
16 e reception is still a bit iffy but i read somewhere
on here that a replacement transponder is on the cards
so i may just wait out.
Fitting the motor was a doddle again thanks to guides/how to,s
on here, i may try and re fix the multi lnb bracket at some stage
just to decrease motor usage and time taken to switch satellites
but for now it all good
Old 4 Weeks Ago   #16
Toute Ronde Bon Oeuf
Tivů's Avatar
Real name: Gordon
Excellent progress
The only time I used multiple LNBs on a Motorised Dish was due to shortage of dosh and an empty spares box!
I started with an 80cm fitted with a 13/19E Monoblock, then some months later added a Motor.
I used the spare Port for 28E only and set a false position of 22.4E.
This meant that the transit time when switching from eg 13E was reduced by that vital second or two.
Later, I broke open the piggy bank and bought a replacement LNB
Tivů is offline   Reply With Quote
Old 4 Weeks Ago   #17
Satcom1's Avatar
My System: 1 Meter Primestar Elliptical C/KU. Twinhan 1025 PCI(Linux), Coolsat 6000, Winegard 76 cm dish. 8' Unimesh, HCC9300 Receiver. Diamond 9000 HD, 1m prime focus, 1.2 m prime focus, both on C Band.
Though defeated by the evil Fresnel this warrier will return victorious!
My system uses C Band lnbf, Circular lnbf and linear lnbf on one motorised dish. Works great for few years now.
Multi Lnb & motorised setup-offsetlnbfs-jpg
I am not a complete idiot, some parts are missing.
Satcom1 is offline   Reply With Quote
lnb, motorised, multi, setup
[IMG] code is Off
