quick help - wind!
Old 13-01-2009   #1
My System: 1m Motorised Technomate dish with Technomate 5400 CI+ Receiver
quick help - wind!
ALright guys,
canny windy weekend here, sat dish was bouncin all over the shop!
Since then, my motor is still switching between satellites spot on, hitting 1w, 13e, 19e no problem, but the quality is right down from like 70% to 45-50% meaning the picture isnt really watchable.
Is this gonna be down to the slant of the dish?
durhamwasp is offline   Reply With Quote
Old 13-01-2009   #2
satelliteman's Avatar
Real name: Paul
Impossible to say. Could be the motor has moved on the pole, dish on motor or dish El.
Take it back to reference satellite and re-align as per the guides.
SM
satelliteman.
An Installers Choice
Follow us on
Old 13-01-2009   #3
guest
Posts: n/a
I realigned my Patio Mounted TD100 this afternoon by giving the edge of the Slab a sharp back-heeler whilst wearing Wellies (Me, not the Slab ...........)
Generally, bad weather causes Azimuth errors more often than affecting Elevation, but check all settings and clamps for signs of having slipped or having been displaced.
You can't be far out, though, as you are still on the margins - perhaps a bit of judicious pressure on the LNB arm whilst someone reports better/worse would point you in the right direction? (If you pardon the pun )
Edit: Whoops! Nearly forgot the obvious test: Jog the Motor a tad either way using the Rx Motor Controls and see what happens. Alternatively, if using USALS, just amend your inputted Longitude by up to, say, half a degree either way. If that improves matters, live the Dish itself until the weather is a bit more agreeable !
Last edited by guest; 13-01-2009 at 08:55 PM. Reason: Rushing to get it right before Oz & James starts.
Old 13-01-2009   #4
Cheers, just what i didnt wonna hear...nothing is simple in the life of a satellite dish! haha
Last night there was still a touch of wind in the air, so the dish was vibrating, therefore the arm and lnb were bouncing, and most pictures were watchable. Then since the wind stopped, and the LNB is dead still, the quality has reduced about another 3% down to around 47, and the picture is pixelated and unwatchable.
Old 13-01-2009   #5
rolfw's Avatar
Real name: Rolf
You may find that the whole lot has moved around the mast slightly, this is easy to check and easy to rectify.
Rolf
Old 13-01-2009   #6
Real name: Paul
Quicker to: with your TM5400CI, press the POS (blue button on remote) and then jog the motor in both directions to see for increased signal readings. It's only a test and if in USALS remember you won't be able to save the setting as this function is for DiSEqC 1.2.... but will tell you if the whole lot had shifted
satelliteman.
Follow us on
Old 13-01-2009   #7
Yeah, did the blue button thing, and couldnt increase it anything significent, maybes 2% or so.
Arrrrrrrgh so frustrating!
Old 13-01-2009   #8
Real name: Paul
It could be dish or motor Elevation movement. Sounds like it needs setting up again on your reference satellite from scratch.
satelliteman.
Follow us on
Old 13-01-2009   #9
i would like to get the ladders out, and use the signal finder while adjusting the tilt of the dish... im just so afraid i'll balls it all up again and be back to square one.
System has been nothing short of perfect for the last month, now a bit of wind and its a touch out, but im not knowledgable enough to sort it. Could do with learning tho, as i guess wind knockin it out could be a frequent thing in particularly bad weather
Old 13-01-2009   #10
Design Engineer/Installer
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions...
what dish is it... what pole and brackets is it on...
can you upload a picture... that might help in spotting why it happened to stop it happening again...
pedro2000uk is offline   Reply With Quote
Old 13-01-2009   #11
Real name: Paul
Use USALS to send the dish to your reference satellite (Thor 0.8W) and then make all the set up adjustments there. Once done, all should fall into place.
See guides in my signature below for set up instructions. In the meantime, a picture as pedro suggested might be of some help to us to identify the problem.
satelliteman.
Follow us on
Old 13-01-2009   #12
Fortec Star Universal Mount
Technomate Diseqc TM 2200 motor
1m dish, think its Orbital 1m
Old 13-01-2009   #13
1m dish, not sure what type
Could have twisted on that mount if it's the one I think it is... how thick is the metal it's made from.
Old 13-01-2009   #14
1w: Nova Sport = 48% signal
13e: Planeta Sport = 61% signal
19e: DSF Sport = 80% signal
Old 14-01-2009   #15
Photos of my set up...
quick help - wind!-cimg5715-jpg   quick help - wind!-cimg5716-jpg   quick help - wind!-cimg5718-jpg   quick help - wind!-cimg5721-jpg
Old 14-01-2009   #16
Real name: Paul
Can't see anything out of the ordinary from those images.
Time to get the ladder out !!
Check Motor EL/Latitude on motor scale is still correct. Latitude will be around 53 and other side of motor scale will show roughly 37. Check with your site and the manual.
See for improvment by springing the dish Elevation but at the end, you'll need to take it back to reference and set up as per the guides
satelliteman.
Follow us on
The Following User Says Thank You to satelliteman For This Useful Post:
durhamwasp (14-01-2009)
Old 14-01-2009   #17
Cheers, thats at 1w there, so my reference position?
Motor elevation and dish elevation, yep they seem like the most likely. As i say, it gets a good signal on 13, 19 and 28, but struggles on 1w now, and thats the one i use 90% of the time!
Old 14-01-2009   #18
guest
Posts: n/a
Another thought: Before you fiddle with the Dish/Motor assembly, carefully examine the fixing points between mount and wall - If one or more of the bolts has been inserted into a mortar course, there is a chance that the mortar has fractured and crumbled as the result of the stresses of wind power. That can lead to the mount going a tiny bit out of true.
The Following User Says Thank You to For This Useful Post:
Old 14-01-2009   #19
Nice neat looking job there and the design of the wall mount looks really tidy...
but, sorry to say this...
If you zoom right in on the bracket, it is typical Fortec Star ... looks OK... but it's just too thin... especially for a 1m on a motor. (probably OK on their dishes because they are also very thin- cut one in half once... with a pair of scissors)
after some strong wind I think it will just be a different shape.... but I do prefer the look to T & Ks.
When the motor was tightened up on that tubing... was it really anchored up and did the pipe distort any...
quick help - wind!-fortec-universal-sat-mount-zoom-arrows-140109a-jpg
The Following User Says Thank You to pedro2000uk For This Useful Post:
Old 14-01-2009   #20
Just spoke to the fella who fitted it, and he thinks the motor may have twisted on the mount.
Gonna have to get the ladders up, when ive got somebody to stand at the bottom!
Old 14-01-2009   #21
I don't think you 'can' tighten a motor up enough on that tubing or really tighten the bolts enough that hold it all together .. it will just crush/ distort if you try to really tighten it all up enough and when it does.... you lose your 100% vertical pole- it goes anywhere as it distorts and it still isn't up to it.
Most on here on a 1m would say use T & Ks with a short length of very solid scaffold tube (c. 600mm) with the motor bolted in the middle... (see satelliteman's quick guide pictorial)...
I think you will be for ever having this 'after strong winds' problem until you strengthen or change the bracket.
Old 14-01-2009   #22
rolfw's Avatar
Real name: Rolf
As said earlier, the most likely movement is of the motor on the mast, as pedro2000uk says, it is practically impossible to tighten the motor sufficiently to prevent movement without deforming the mast on that type of mount.
The first few motors I fitted were on standard gauge 2" steel mast and I had nothing but problems with them, so thereafter moved onto the much heavier gauge scaffold tube.
Rolf
Old 14-01-2009   #23
Cheers for all the help guys - just been up the ladder, and moved the dish elevation about 1 degree, now my signal is around 70% on 1w, and 95% on 13 and 19 e.
Old 14-01-2009   #24
guest
Posts: n/a
Well done - there is little to fear (apart from falling off!) from having a little fiddle ...................
Old 14-01-2009   #25
I totally agree about my bracket, i actually have a T & K lying in the garage. Thats the next task...
quick, wind
[IMG] code is Off
