2 LNBs on a 60cm dish, possible?
Old 19-01-2009   #1
TWY
My System: Newbie
Hello!
I just bought a 60cm transparent dish, and i would like to know if i can put two heads on it to receive Astra 19 and Hotbird 13? I live in London!
Many thanks
T
TWY is offline   Reply With Quote
Old 19-01-2009   #2
guest
Posts: n/a
I suggest you use a 6 degree Monoblock LNB (Two heads in one unit).
Although designed for optimal performance with 80cm Dishes, they will work happily with a 60cm Dish in a strong signal area (like yours) and are easier to set up than two single LNBs on a bracket.
The Following User Says Thank You to For This Useful Post:
TWY (19-01-2009)
Old 19-01-2009   #3
satelliteman's Avatar
Real name: Paul
Also, the mono will save you fitting a DiSEqC switch
EDIT: Thread moved from Satellite Meters and Installation Equipment section
satelliteman.
An Installers Choice
Follow us on
The Following User Says Thank You to satelliteman For This Useful Post:
TWY (19-01-2009)
Old 19-01-2009   #4
Robbo's Avatar
Real name: Mark
Actually you can put three on if you want, eg 9e, 13e, 19e. That will work too, but you need LNBs with smallish heads, like the Inverto singles.
Using separate LNBs is good if you want to feed 28E from another dish to the receiver too.
Old 11-03-2009   #5
My System: Dreambox 500s,Technomate 6900 Andrews 1.2m dish,Sky HD
Just installed 3 lnbs on a 60 cm Triax 19e,13e and 28e Worked well!
hondamt is offline   Reply With Quote
The Following User Says Thank You to hondamt For This Useful Post:
divibi (11-03-2009)
Old 13-03-2009   #6
aba
My System: chaparral montery 40 fully loaded ehcostar ad3600ipvia 3 dishes zone 2 / 1 mt motorized / 2.3 m motorized
a 6 degree Monoblock LNB will not work correctly on a 60 cm dish
they are made for 80 cm dishes
aba is offline   Reply With Quote
Old 13-03-2009   #7
Robbo's Avatar
Real name: Mark
They may not work as well as they do on an 80cm dish, but they work well enough, expecially since both satellites are very strong in Europe and the UK.
Old 13-03-2009   #8
Real name: Paul
I believe some monobloc's work on a zone 2 also.
satelliteman.
Follow us on
Old 13-03-2009   #9
rolfw's Avatar
Real name: Rolf
I recently set up a 60cm with a 6 degree monobloc for 13 East and 7 East, centred on 7 East, it still gave a workable signal on Hotbird, but was nearly a degree out.
Rolf
60cm, dish, lnbs
[IMG] code is Off
