3 LNBs 2 recievers signal problemInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 25-01-2009 Location: Ireland
My System: 2 Dishes 80cm Dreambox and Topfield 3 Quadra LNB 2 DiSeq |
Hi everyone! The strange problem we have is as follows: First the kind of system setup we got: Two dishes on one two quadro LNBs on second one quadro LNB to get 13E, 19E and 28. Which are connected to Diseqs to distribute signals to two receivers. Everything is kinda OK but.. One receiver looses signal for some channels (not all just some) when other receiver is switched off or switched to another satellite. This is so annoying.. Where could be a problem?? Thanks, | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorks, uk
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | you dont need to use quattro lnbs as these are for multiswitch systems ordinary quad lnbs would have worked fine, is this what you mean ? | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | There can be a problem with some Quad LNBs (I presume you mean Quads), whereby they don't seem to be powered by all ports, try experimenting by changing the ports of the second switch, so if you have them connected on 1 and 2, try 1 and 4. | ||
| | #5 | ||
My System: 2 Dishes 80cm Dreambox and Topfield 3 Quadra LNB 2 DiSeq | Did mess around with ports and it didn't work really ![]() But if problem is in LNB, then why one receiver works well but another doesn't? And when one receiver is ON the second receiver gets all channels as well. | ||
| | #6 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Well I've never personally had a problem, but I know that some have. | ||
| | #7 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | | ||
| | #10 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | When one receiver is powered off and you lose channels, are they from one satellite or all satellites? Also try changing the ports on the diseqC switches. | ||
| | #12 | ||
My System: 2 Dishes 80cm Dreambox and Topfield 3 Quadra LNB 2 DiSeq | I did try to swap ports on Diseq and LNB. Didn't change anything. LNB position? When both receivers are ON the signal from all satellites is 99%. | ||
| | #13 | |||
My System: 2 Dishes 80cm Dreambox and Topfield 3 Quadra LNB 2 DiSeq | Could it be like one receiver works as amplifier? Our cable runs not so long, 20m maybe... | |||
| | #14 | ||
| Member Join Date: 21-08-2008 Location: MERSEYSIDE
My System: SAT/CABL | hi i had a problem 6 months ago just like what your having i got some one in too look at it ,what it was some thing to do with H/V setting if one receiver is on .H. and the other is on .h. both work OK but if you try putting one on the .v . you loose the channel .this is what was wrong with mine .if that makes any sense to you .[ some thing to do with SYMBOL RATE . | ||
| | #15 | ||
My System: 2 Dishes 80cm Dreambox and Topfield 3 Quadra LNB 2 DiSeq | Thanks for your concern.. I know what you mean.. but how it was sorted out? I thought if I have quad LNB and Diseqs I shouldn't have problems vith polarisation..? | ||
| | #16 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | That's right, you shouldn't have problems, but it does occasionally happen. | ||
| | #17 | ||
My System: 2 Dishes 80cm Dreambox and Topfield 3 Quadra LNB 2 DiSeq | Sorted!!! I did climb to the atic to check cables. One cable was connected together with splitter (1 in 2 out). I removed the splitter and and connected cables. And...!!! Everything works!! Installed third receiver in bedroom. All receivers work fine now from all satellites. Happy days.. | ||
| lnbs, problem, recievers, signal |
