120cm fibre dish, anyone knows this brand?
Old 03-02-2009   #26
Design Engineer/Installer
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions...
Originally Posted by pipino View Post
those LNBs have WR75 connection and not C120 you would need a polariser (mecanic better) in the same time it will do a convertion from WR75 to C120 (feedhorn or depolarizer)
Is that lnb DRO or DLL...?
pedro2000uk is offline   Reply With Quote
Old 03-02-2009   #27
Sat Freak
pipino's Avatar
My System: Motorized Gibertini OP150 ,Motorized Fibo MF90, 2X ASC signal 1.20 on stand by,ASC signal 1.80 ,Famaval 1.80 , 60cm eliptical raven ..hirschmann fibre glass 1.20m....and more gadgets
i would say a DRO ,as i remember we could tweak the oscillation frequency by the turning the big Trimmer inside,we cant do that with PLL lnbs
http://www.satellites.co.uk/satellite/signaturepics/sigpic87537_4.gif
pipino is online now   Reply With Quote
The Following User Says Thank You to pipino For This Useful Post:
divibi (05-02-2009)
Old 05-02-2009   #28
On the outside of most LNBs (f's or C120's) in the plastic cover or visible on all metal cased ones... there are what look like 3 production final fine tune screws -usually 2 together & 1 on its own.. do you know what is for what....
Old 05-02-2009   #29
Sat Freak
pipino's Avatar
thats to tweak the oscillator,usualy is done in the labs before they get into the market
divibi (05-02-2009)
Old 05-02-2009   #30
Thanks Pipino...
Do you know what the 2 are for and what the one is for exactly .. and what can you tweak... it's performance over the whole of KU ... move a peak point up or down KU (hmmm) ..... lift a frequency and loose it elsewhere.. .... blow it up/melt it... or the stb!
I know fine tuning waveguides can come down to drilling a hole, bunging a screw in the waveguide and screwing it in and out to see if it helps bounce the flow .. very exacting science ... as is so much of radio electronics... a mix of complex, accurate formulas and inspired (or blind) guesswork...
Wouldn't be the same if it wasn’t.
Old 05-02-2009   #31
Lightbulb UNI' LNB L.O. fine adjusters 9750/10600
OK ... the two screws are for 9750 & 10600 local oscillator blocks.... to fine tune each by simply bringing pressure on them to fine tune their frequency by how solid or loose they are held...
(Think I did all this 10 years ago... hmmm... used to be only one then.....)
can't remember if it didn't 'shift' the L.O. frequency 'offset'... so it could mess the frequencies up without modifying the LO settings as well ....... depends on the range as to it's usefulness.
120cm fibre dish, anyone knows this brand?-lnb-lo-blocks-adjusters-close-up-txt-1a-jpg
Old 05-02-2009   #32
Sat Freak
pipino's Avatar
all correct ,i also use to play with the old MASPROSs and SPCs to get hight and lower bands ,can be modified to work as a transmiter too,,god we are talking more than 20 years ago
Old 05-02-2009   #33
I think it is c. 20 years.. just remembered what I was doing 10 years ago..
note to self... must cut down coffee ............ (that'll happen).
120cm, brand, dish, fibre
[IMG] code is Off
