120cm fibre dish, anyone knows this brand?
Old 28-01-2009   #1
kamaleon's Avatar
My System: skystar2 pci skystar usb + porty lidl camping dish maybe one day i'll have a dreambox 500s...
Hi folks I've found someone that's selling this dish not far away from me, anyone knows what make is it? it says SEMAC but I've never heard of it. TIA!
120cm fibre dish, anyone knows this brand?-dscn4632-jpg   120cm fibre dish, anyone knows this brand?-dscn4633-jpg   120cm fibre dish, anyone knows this brand?-dscn4634-jpg
kamaleon is offline   Reply With Quote
Old 28-01-2009   #2
Design Engineer/Installer
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions...
Could be ex Turkish naval encrypted coms gear... looks very well made.... check the frequency on the lnb etc..
pedro2000uk is offline   Reply With Quote
Old 28-01-2009   #3
kamaleon's Avatar
Coincidentally, scrolling down this forum section I found a link to this Ebay seller, he seems to be selling a dish slightly similar:
Ebay 320314514800
otherwise, the lnb on the unknown brand fibre dish is a pretty old one, and the fitting for it seems to have been DIYed. What should I check for? Why?
120cm fibre dish, anyone knows this brand?-dscn4635-jpg   120cm fibre dish, anyone knows this brand?-dscn4637-jpg   120cm fibre dish, anyone knows this brand?-dscn4630-jpg
Old 28-01-2009   #4
if it's been modified it won't be the original - the original would have given clues to it's use but also to the spec it's been made for... f/d ratio focal length etc.. and possibly the optimum frequency of the reflector material in the fibreglass.
Old 28-01-2009   #5
kamaleon's Avatar
rightey, I (sorta) get it. You mean the actual lnb should specify the reflector material frequency? didn't realise that. I'm not particularly interested in this dish, but the seller also has a nice fibostöp and he only wants to sell the two of them unfortunatly
Old 28-01-2009   #6
the size of the dish & the fact he's used it for dth probably means it's OK* ... the build quality looks very good indeed - depends on the price too...
*ask him what sort of results he got on given known weak sats etc..
Old 28-01-2009   #7
kamaleon's Avatar
He's not very friendly, unfortunatly I can't ask him anything else. I'd be keen on getting the fibostop but I have to get this one as well, problem is I have nowhere to put it, and I don't know how to sell it to anyone...
since we speak about the lnb and the holder, here's some more pictures of it
120cm fibre dish, anyone knows this brand?-dscn4628-jpg   120cm fibre dish, anyone knows this brand?-dscn4641-jpg   120cm fibre dish, anyone knows this brand?-dscn4642-jpg   120cm fibre dish, anyone knows this brand?-dscn4643-jpg
Old 28-01-2009   #8
CROSSBONES's Avatar
My System: 1.2M, & 55cm Gregorian Dish`s, 1.8m Precision dish Jaeger 1224 H-H motor.Dreambox 800, Vbox-II. SS2 Card.
What size Fibo has he got? The other dish looks good, the polar mount looks nice and strong
CROSSBONES is offline   Reply With Quote
Old 28-01-2009   #9
kamaleon's Avatar
90cm one, I'm still yet to find a second hand 120cm one Do you think it's a good dish Crossbones?
Old 28-01-2009   #10
CROSSBONES's Avatar
It does look good, but you may have a problem fitting an lnb to the feed.
Old 29-01-2009   #11
selector's Avatar
My System: DB 500 S, 90 cm, Eurostar ESKD-T2 Twinfeed
FiberglassEpoxy
I think they are manufactured in Poland
http://www.laminas.com.pl/
selector is offline   Reply With Quote
Old 29-01-2009   #12
kamaleon's Avatar
Thanks for the info mate, I'm not sure they're the same though. They don't look like it.
Crossbones, you're probably right
Old 29-01-2009   #13
Sat Freak
pipino's Avatar
My System: Motorized Gibertini OP150 ,Motorized Fibo MF90, 2X ASC signal 1.20 on stand by,ASC signal 1.80 ,Famaval 1.80 , 60cm eliptical raven ..hirschmann fibre glass 1.20m....and more gadgets
the LNB on it is from a very good LNB maker "California Amplifier" ,i never seen a wideband version on those LNBs,i bet it works very good too for DX stuff
pipino is offline   Reply With Quote
Old 29-01-2009   #14
kamaleon's Avatar
you mean for feedhunting?
Old 29-01-2009   #15
Sat Freak
pipino's Avatar
yes..if you want to call it
Old 29-01-2009   #16
You'd soon mod an LNB holder ... the .8db/.9db wideband KU LNB's worth a play but you'd probably beat it with a £5 LNBf.
Old 29-01-2009   #17
Sat Freak
pipino's Avatar
not always m8 ,specialy if you are playing with 4.2.2 or very low Symbol rate tansmission ,i find those OLD generation wide band LNBs more effective
The Following User Says Thank You to pipino For This Useful Post:
divibi (30-01-2009)
Old 29-01-2009   #18
Originally Posted by pipino View Post
not always m8 ,..........
I agree ... you never know ..
Old 29-01-2009   #19
kamaleon's Avatar
ok, now I understand your previous statement on DX better
what makes them better, anyway?
Old 29-01-2009   #20
Sat Freak
pipino's Avatar
its build very well and with care ..most of them are individualy hand ajusted in the labs..nothing compare to uncle chinachun
divibi (30-01-2009)
Old 30-01-2009   #21
kamaleon's Avatar
So you think this oldish looking lnb might perform better than the newer C120s like inverto, etc? Does it have a polariser (is that what one can see on the last couple pics)? I notice the neck of it looks square. Will it mount on a C120 round feedhorn? Sorry for the dumb questions
Old 30-01-2009   #22
Sat Freak
pipino's Avatar
those LNBs have WR75 connection and not C120 you would need a polariser (mecanic better) in the same time it will do a convertion from WR75 to C120 (feedhorn or depolarizer)
divibi (31-01-2009)
Old 30-01-2009   #23
kamaleon's Avatar
oh dear sounds a bit too full on for me...
Old 30-01-2009   #24
Sat Freak
pipino's Avatar
we are talking hard core DX-SAT stuff here my friend ..
Old 31-01-2009   #25
kamaleon's Avatar
I don't necessarily understand all the bits and pieces but I can at least tell that you're talking about hardcore DX stuff, yes
120cm, brand, dish, fibre
[IMG] code is Off
