Help needed with DiSEqC settings
Old 28-01-2009   #1
My System: Topfield TF5050CI Common interface digital satellite receiver
Question Help needed with DiSEqC settings
I would be grateful for any hep with a problem I have. I have a dish with 2 lnbs one pointed at Astra1 and the other at Hotbird with a single cable running to my receiver. My Humax expired so I have just bought a Topfield TF5050 CI to replace it and am having difficulty downloading Hotbird channels using automatic and manual searches. It seems that I am not able to get the box to switch to Hotbird.
The manual talks about DiSEqC settings but although I can get to the menu I do not know what settings I should enter. I need to be able to get the lnbs to switch but do not know how.
Can anybody help me please!
novestonback is offline   Reply With Quote
Old 28-01-2009   #2
guest
Posts: n/a
I'm not familiar with that Box, but they all behave much the same way:
Set DiSEqC for Hotbird to A or 1 or something similar.
Set Astra1 to 2 or B or similar.
It's that easy.
The only thing you can do wrong is get them reversed - and that is simple to sort out!
Generally things default to "A" and, as you appear to be getting Astra 1 by default, maybe Hotbird should be "B" (Depends which LNB you've connected to which DiSEqC switch Port .....................)
Old 28-01-2009   #3
satelliteman's Avatar
Real name: Paul
In addition to above, believe Topfields have a Mini-DiSEqC setting for 2 way swicthing also
satelliteman.
An Installers Choice
Follow us on
Old 28-01-2009   #4
Smile Thanks
Using the information you both have given me I have worked it out. Simply did not realise that you had to change the setting for both lnbs. Thanks guys for your help.
Old 28-01-2009   #5
Real name: Paul
All good news, well done
satelliteman.
Follow us on
Old 29-01-2009   #6
guest
Posts: n/a
Well done - it's all quite logical .....................
.................... In retrospect!
diseqc, needed, settings
[IMG] code is Off
