Motors versus Multiple LNBs
Old 28-01-2009   #1
My System: Sony Bravia 40 inches model KLV-40V400A full HD, Samsung Digital Home Cinema System model HT-Z315, Dreambox HD 800, Nilesat, Hotbird, Nintendo Wii, Xbox 360, Aztech ADSL2+ Wireless router 1Mbps
Hi all, I admit I'm a newbie and I would like to know the advantages/disadvantages between using a motorized system against using multiple LNBs instead. What is the reason for going for such technologies rather than using the usual fixed dish?
thanks
mad_elf is offline   Reply With Quote
Old 28-01-2009   #2
guest
Posts: n/a
DiSEqC Horizon-Horizon Motors (Used on Dishes up to a metre or so) can be quite slow to track across the arc, but are cheap and easy to set up.
Multi-LNB solutions offer instant Satellite switching and (in my opinion!) can be tricky to set up - although there are custom made brackets available for some Dishes which take a lot of the pain away.
Also, there is a limit to the number of Satellites that a multi-LNB Dish can see, whereas a Motorised Dish of a suitable size can get useful results on most of the Satellites in the visible Arc.
Old 28-01-2009   #3
Robbo's Avatar
Real name: Mark
Here in Europe we have many satellites to choose from, hence the desire for either a motorised dish, multi LNB or multi- dishes.
The motor is the most flexible and gives a the widest choice of satellites for the least cost. Disadvantage is you have to wait for the dish to move and it is less convenient to run more than one receiver from it.
Multi-LNB brings fast switching between satellites, and easier to have multiple receivers. The cost increases way above a motorised dish once you start adding more than 3 or 4.
Old 28-01-2009   #4
My System: 2 x DM7020 CM 1.2
Well, I have the best of both worlds, I have dish diseqc controlled with 28e, 19e and 13e and a motorised dish for the rest, all automatically controlled from a Dreambox DM800
dubious is offline   Reply With Quote
Old 28-01-2009   #5
kamaleon's Avatar
My System: skystar2 pci skystar usb + porty lidl camping dish maybe one day i'll have a dreambox 500s...
dubious, I have pretty much the same setup technisat 45cm dish for 28.2°E, 19.2°E, 13°E on a spaun 4:1 switch, the spare entry on the switch goes to the motorised dish lnb as it is a twin (pretty clever hey lol) I can always watch at least 2 programs on my screen as I have 2 pc cards (one skystar to move the dish and one dvb-S2 on the switch / 2nd motorised lnb out)
Motor: a lot of different satellites, one cable run, maybe cheaper when compared to a lot of different lnbs in a big multifeed setup; zapping is slow and motors can make noise (neighbourhood trouble)
Multifeed: expensive if you want loads of satellites (lnbs, switches, multifeed dishes like wavefrontier, etc), but you can share it with other people if your lnbs are twins, quads, etc, instant zapping, but you need more cable runs and it usually takes more space, etc.
kamaleon is offline   Reply With Quote
Old 28-01-2009   #6
Robbo's Avatar
Real name: Mark
Yes, with a purpose made bracket and after doing a few, they're not too bad. Less bother than a motor to setup I think.
Old 28-01-2009   #7
My System: Sky; Raven 90 multi-LNB 1W, 7E, 9E, 13E 16E, 19E; 1m Orbital dish on Moteck SG2100 motor; Technomate 1500, Phoenix Apollo and Kathrein (analogue) etc etc Receivers
In terms of setting up, I think that what can make a multi-LNB set up apparently more difficult is if the set-up is in a position difficult to access; then, aligning each individual LNB for the more tricky satellites can be a nuisance. In my case I have my multi-LNB set up ground mounted and, as a result, I find it a doddle to mess with such that it is really a toy that started with three LNBs which somehow (I wonder!) quite rapidly grew to 6 LNBs - receiving a total of seven satellites (as an LNB for 7e also brings in 9e).
As it happens, I also have a ground mounted motorised dish using a Moteck 2100; can someone tell that I don't like the hammering things into wall aspect of satellite instalment?
PS Ah, just realised I must update my profile!
bigtee is offline   Reply With Quote
Old 29-01-2009   #8
Robbo's Avatar
Real name: Mark
Yes, I agree with you bigtee, doing the multiLNB in situ is difficult when mounted on a wall, even with a standoff on a ladder.
However, I normally set them up on a vertical pole at ground level, then as long as the pole on the wall is vertical too, it's just like putting a singly focussed dish up, as all adjustments have already been done.
What switch you using bigtee?
Old 29-01-2009   #9
Ah Robbo, I will check the name/make of the switch tomorrow but it is an 8 way (I think) that I bought on American Ebay. As it happens, last year B&Q were stocking 6 way (I think) switches and I really should have stocked up on that because I haven't seen them since.
Old 29-01-2009   #10
Thanks for your replies. Picture is clear now
Old 29-01-2009   #11
guest
Posts: n/a
Good one!
Old 29-01-2009   #12
kamaleon's Avatar
what have you cleared up? care to share the keys? which encryption system?
Old 29-01-2009   #13
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4
How slow is slow? For example to get from 28.2E to 30W how long would it take?
Huevos is offline   Reply With Quote
Old 29-01-2009   #14
kamaleon's Avatar
Last week I took my chronometer and marked 45sec between 50W to 50E, can't remember if that was on the fast or the slow speed though...
edit: just benchmarked 32sec from 30W to 28.2E at full speed and 48sec at low speed. Using a moteck SG2100, that is
The Following User Says Thank You to kamaleon For This Useful Post:
divibi (30-01-2009)
Old 30-01-2009   #15
guest
Posts: n/a
1.9 deg/sec @ 13v
2.5 deg/sec @ 18v
(Typical H-H Motor)
The Following User Says Thank You to For This Useful Post:
divibi (30-01-2009)
Old 30-01-2009   #16
kamaleon's Avatar
Well the moteck's way faster than that as you can se above so I'm not sure about those figures?
Old 30-01-2009   #17
Robbo's Avatar
Real name: Mark
hmmm..
28.2+30=58.2
Rai's figures.
58.2/1.9 = 30.63 secs (slow speed)
58.2/2.5 = 23.28 secs (bit faster speed)
Old 30-01-2009   #18
guest
Posts: n/a
They are printed in the spec. - not only for my SG2100, but also for my "spare" which is a Fortec Turner (Motek Clone).
So, as Robbo rightly calculates, it's your Motor that's slow ....................... compared to spec.
Old 04-02-2009   #19
My System: Dm500s
Hi All i have multi LNB i need to scan through all of them but i managed to get throught Nilesat only can any one tell me how scan other LNB Too??
would appreciate your help
burhanhd is offline   Reply With Quote
Old 05-02-2009   #20
Its similar to scanning multiple dishes. Just select your configuration in the menu prior to the scan.
lnbs, motors, multiple, versus
[IMG] code is Off
