2 CM 1.2m's how close behind each other?
Old 30-01-2009   #1
GreenmanBelg's Avatar
My System: 1 x CM 1.2m matching C120 feedhorn and Invacom 0.3db twin output LNB.50 degrees East to 42 degrees West.1 x CM 1.2m AZ/EL mount matching C120 feedhorn and twin output Invacom 0.3db Humax VACI 5300 Old Panasonic Digibox with IRL $ky sub. Coship FTA
Question 2 CM 1.2m's how close behind each other?
Hello,
I want to place another CM1.2m dish on a pole beside my current one. How close can they be? Enclosed a pic.
Thanks.
2 CM 1.2m's how close behind each other?-dishes_in_the_snow_22-11-08_5-jpg
Regards JD Belgium.
GreenmanBelg is offline   Reply With Quote
The Following User Says Thank You to GreenmanBelg For This Useful Post:
divibi (31-01-2009)
Old 30-01-2009   #2
Sat Freak
pipino's Avatar
My System: Motorized Gibertini OP150 ,Motorized Fibo MF90, 2X ASC signal 1.20 on stand by,ASC signal 1.80 ,Famaval 1.80 , 60cm eliptical raven ..hirschmann fibre glass 1.20m....and more gadgets
you can put it behind in the oposite side ,but make sure you add about 50cm higher on the mast,i think it should be fine ..but wait for more suggestions...cheers
http://www.satellites.co.uk/satellite/signaturepics/sigpic87537_4.gif
pipino is offline   Reply With Quote
Old 30-01-2009   #3
Robbo's Avatar
Real name: Mark
It depends which way is south?
and where is the dish pointing in the photo?
Old 31-01-2009   #4
Sat Freak
pipino's Avatar
i would say is pointing towards nilsat..
here is a sample more less of what was my idea
2 CM 1.2m's how close behind each other?-dishes_in_the_snow_22-11-08_5%5B1%5D-post-jpg
Old 31-01-2009   #5
Wink
Thats great pipino thats what I'll do. Will get my pal to get it sorted.
Stand by for more pics.
Yes its pointing at Nilesat.
As per my pic the big Triax is looking at Arabsat and the little lad below is looking at Astra 2.
Thanks.
2 CM 1.2m's how close behind each other?-new_setup_26-01-09_7-jpg
Regards JD Belgium.
divibi (31-01-2009)
Old 31-01-2009   #6
rolfw's Avatar
Real name: Rolf
That will be an awful lot of stress on that wall.
Rolf
Old 31-01-2009   #7
Good point.
That wall where the pole is attached to is a disused attic, whats the worst that can happen?
If it was damaged I know someone who could repair it.
Remember that guy in the north of England with the 2.4m dish attached to a wall, I wonder how he's getting on?
Any views welcome.
Regards JD Belgium.
Old 31-01-2009   #8
Sat Freak
pipino's Avatar
yes thats correct the stress would be very high ,but with some common sense you should plan some supporting way to ease a little on the whole thing..good luck
The Following User Says Thank You to pipino For This Useful Post:
divibi (31-01-2009)
Old 31-01-2009   #9
Any suggestions?
What about 2 braces going right across the inside?
Lots to think about.
Regards JD Belgium.
Old 31-01-2009   #10
rolfw's Avatar
Real name: Rolf
That may help, what thickness is the wall and is it cavity or solid?
Rolf
Old 31-01-2009   #11
Its a wall with a cavity ie double course of bricks.
Regards JD Belgium.
Old 31-01-2009   #12
Sat Freak
pipino's Avatar
i would ask a professional builder to see this,we only can help you virtualy
Old 31-01-2009   #13
Wink
Thanks for that, as I type I'm thinking of a ground location close by, that might take the pressure off.
Thanks everyone.
Regards JD Belgium.
Old 31-01-2009   #14
Site administrator
Analoguesat's Avatar
Originally Posted by GreenmanBelg View Post
Good point.
The brackets overstress the wall in a gale and bang - down comes the entire wall and wrecks all the dishes!
How about a diagonal brace from ground level to the pole to reduce sideways stress?
Analogue forever!
Old 31-01-2009   #15
Not possible as then car would not fit out the gate.
I'm going to leave as is and I'm going to place the other CM 1.2m in another location.
I'll take my chances with as is. If I suffer sat melt down I'll post pics. Be sure I won't lose sleep.
Thanks.
Regards JD Belgium.
Old 31-01-2009   #16
My System: SKY HD
Myself i would not do it the wind load on that little bit of wall would be very high on a windy day, What is that building used for is it just a outhouse or shed?
Hello,
Thanks.
satpro is offline   Reply With Quote
Old 31-01-2009   #17
Wink
Thanks for that Wod I'm going to put the dish on another location ie in the garden so that takes the heat off.
Pics to follow.
Regards JD Belgium.
Old 31-01-2009   #18
wod
wod's Avatar
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+
what's these mounts that go through the roof and fix to the roof timber as they might be an ideal as it would be into the roof and deflect the wind a little
or if the direction of 7west is clear maybe you can have a 1.2 or even 1.5m fixed for that on a ground mount instead of mount one next to the 1.2m
Old 31-01-2009   #19
Sat Freak
pipino's Avatar
@GreenmanBelg
are you planning to put a motorized C band with that new CM120??
Old 31-01-2009   #20
Question
Not sure what you mean?
Regards JD Belgium.
12m, close
[IMG] code is Off
