Motorised dish-true northInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Regular Member Join Date: 04-06-2004 Location: Malawi
My location is Blantyre Malawi Latitude -15.783 and longitude 35.00, and if am setting up a motorised dish what satellite can i aim as my true north satellite? | ||
| | #2 | |||
| Design Engineer/Installer Join Date: 08-08-2007 Location: Central UK, E Cheshire ..near Jodrell
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions... | If it is KU Band you are aiming for you can use 36e (only 1 degree to the east) and the Multichoice Africa channels ... you will not get a picture without a card and only one clear radio channel.... but it will let you set up the start of your arc and done properly from the start... all the other satellites will come in OK. (I would avoid 35e because it is off arc- inclined I think). for linear KU try 36e ... 12399H ...SR=26480 (apid 465 = audio for the French radio audio) very strong.. | |||
| Specialist Contributor Join Date: 07-05-2008 Location: NW, Ireland
My System: DM 600-S, AB IPBox 9000HD, Moteck SG2100, Fracarro Penta 85 dish, + some puters | Go to this site and enter your location. _http://www.dishpointer.com/ You can work it out from there, Eutelsat @ 35E would be your true north, but I dont know if you can receive any signal from it at your location. You could use some of the sats either side of it like 32.8E, 33E, 36E, 39E etc. Use whichever is closest to your true north where you can receive a signal. EDIT: I'm too slow for pedro ![]() I take it I posted a live link, If so it was accidental | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Yes deactivated it, no worries compufunk | ||
| dishtrue, motorised, north, true |
