0% Strength, 0% Quality?Information exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 02-01-2009 Location: Czech Republic
My System: None yet - still researching |
Hey all, I just received my first sat system and decided to install it today. I live in the Czech Republic, and I'm not trying to get the UK channels, mainly the Czech ones for the wife and a few French channels for myself. I'm targeting the sats at 19.2 and 23.5. Just for background, here is my setup: LH 80cm dish Inverto IDLP-40MONO Monoblock LNB AZBox HD Elite Now, I assembled the dish as per the instructions, but for some reason, no matter where I point the dish, I always get 0% strength and 0% quality. I would expect to get at least _some_ signal, be it even only noise. Here is my question: is it normal to get absolutely no signal unless being exactly on spot on the sat? Or do I have a defective LNB or receiver? And in the latter case, how can I test those, without buying new gear if possible? Thanks! | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Welcome, Sounds like it's not set up properly. Assuming it's a DUO 4.3° mono LNB, you'll have to install and align the dish for either 19e or 23.5e focal depending on which side you mount in the holder. Make sure you have the receiver set up for DiSEqC 1.0 LNb switching. In answer to your main question: You need to be aligned to the satellite to get a signal lock, yes. | ||
| | #3 | ||||
My System: None yet - still researching | Thanks for the quick reply!
The receiver has a lot of settings for DiSEqC switching (1.0-LNB1 to 1.0-LNB4, Mini-LNB1 and Mini-LNB2, 1.1-LNB1 to 1.1-LNB16 and some switch settings). Should I choose DiSEqC 1.0, mini, or 1.1? And do I have to choose a different LNB for each satellite? ) is to rotate the LNB about the dish (for polarization). Could it explain why I can't get any signal?Thanks again for the reply, this is very useful! | ||||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Hi, I would suggest that you forget the monoblock for the moment, and get the dish set up with a single LNB. This will both simplify things for you to start with, and give you the confidence to tackle the monoblock. I have never heard of a 6 degree monoblock working with 4.3 degrees separation on an 80cm dish, unlikely to work I think. (Feel free to prove me wrong though I always use Diseqc 1.0 for monoblocks, not had a problem, it will switch OK with that. Maybe some work with mini diseqc, I don't know. Check your dishpointing using dishpointer.com | ||
| | #5 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | You need a 4.3° for these two satellites also known as a DUO monobloc. Either use the above monobloc or a signal LNb as said to lock onto either one of the satellites required. DiSEqC 1.0 or mini-Diseqc work with 2 way LNb switching. For multi LNb theory also applies to monbloc's, take a look here: http://www.satellites.co.uk/satellit...guide-pdf.html | ||
| | #6 | |||
My System: None yet - still researching | Thanks for the reply!
![]() Thanks for the advice, will do that! | |||
| | #7 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | As said, you require a 4.3° for these two satellites also known as a DUO monobloc. | ||
| | #8 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | It must be a typo then, I reckon. No-one in their right mind would recommend using a 6 degree monoblock for 4.3 degree separation. Although, on a greater than 80cm dish (eg 1m) the spacing may well be about right. | ||
| | #9 | ||
My System: None yet - still researching | Thank you mates for your invaluable answers. I'll give it another shot today with my current gear, but if I can't get it to work, I'll get a single LNB tomorrow, and one of those satellite finder devices to boot. I'll keep you posted about my progress! Thanks again! | ||
| | #10 | |||||
My System: None yet - still researching | So basically, I am now seeing both sats now. And yes, with a 6° monoblock and an 80 cm dish, I see 19.2 and 23.5! Maybe had to compromise some signal quality though (I get 95% strength and 80% quality on both). Now I'm off discovering how to find my way amongst hundreds of channels ![]() Thanks a lot! | |||||
| | #11 | ||
| Member Real name: Silvio Zacharias Join Date: 08-03-2009 Location: Cyprus,Nicosia
My System: eutelsat16E,hotbird and SIRIUS 4.HP pavilion | normally even if you are not on the sat,you got to have a little quality,so..SHURE you have a problem!and maybe it is the lnb | ||
| | #12 | |||
Great news, well done. ![]() I'll make a note of that one, I have now heard of someone using a 6 degree monoblock for 4.3 deg separation and getting it to work. I suppose that if the error is split between the two sats, each LNB is less than a degree out. | |||
| quality, strength |
