Low strength and qualityInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 01-02-2009 Location: Spain, Alicante region
My System: 1.9 Metre dish with |
I am not receiving any stations and the strength is down to 5 and quality 28. This happened yesterday afternoon, no reason that I can think of that would have caused it. I have checked the connections and they are good, power is at the motor and the dish hasnt moved. Could the LNB be defective? The same problem happened a few weeks ago and as soon as I started to check the dish and connections the strength went up but there was no obvious sign of a defect. Should I just go out and buy another LNB? | ||
Lnbs are not expensive these days and they do fail and in doing so can display very odd characteristics, I had one go a few years ago and it would sometimes work but mostly display no signal. There have been instances where a spider has managed to invade the lnb and only hides when you approach the dish. | ||
| low, quality, strength |
