Newbie questions, attempting 1st motorised setup
Old 30-03-2009   #26
Robbo's Avatar
Real name: Mark
There are only 3 main types of scan: blind scan, transponder scan and single tranponder scan. The blind scan should be used sparingly as it will quickly fill up your memory. There is also the NIT scan, which I presume obtains transponder info from the satellite itself.
Old 30-03-2009   #27
Real name: Karl
My System: Waiting for TM-6900 SUPER HD Combo Diablo 2.3 Cam Cas int 3+ installed on Vista home premium Triax 80cm fibre glass dish, bolt on 36-volt Jaeger 128 H to H motor, Titanium 0.2dB LNB. V Box
"Memory"
Should I delete channels that I can not get or do not want? rather than just working from a fav list
Blade_uk is offline   Reply With Quote
Old 30-03-2009   #28
Robbo's Avatar
Real name: Mark
Whichever you prefer, I tend to not use favourites with a motorised dish as I don't want it wanging back and forth all the time. Deleting unobtainable or invalid channels does take a lot of time though, I tend to just put the ones I watch, at the top of each satellite's transponder list. I can never be bothered to delete the ones I don't want, but since I don't have blind scan, it doesn't cause a problem.
1st, attempting, help or advice, installation, motorised, newbie, questions, setup
[IMG] code is Off
