Quality ratios between satellitesInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 11-08-2006 Location: Hants
My System: 90cm Fortec star offset dish. Fortec star motor. Fortec star 0.2 FCKUVN LNB. Technomate 6900 Super Manhatten Plaza ST550 Reciever |
Looking at SatMans improved quality http://www.satellites.co.uk/satellite/picture-members-setups-general-satellite-installations/130365-triax-td88-vs-fracarro-penta-85-a.html I was wondering if there is a list of typical quality values that should be achieved for say 28.2E, 1W & say 30W or a ratio between them? This might be handy to know so that you could check that the arc is being correctly tracked. I know it depends on where you are located but would be nice if there was a general value for the larger cities in Europe. Id be interestested particuarly in sw London. | ||
| The Following User Says Thank You to satbadger For This Useful Post: | divibi (13-03-2009) |
| Regular Member Join Date: 09-12-2008 Location: east Anglia
My System: motorised dish and technomate receiver | I think that there are too many variables. Output power output of different satellites variable slant path loses between satellite and receiver size and gain of the dish gain of the lnb length and losss of the coax cable sensitivity of the receiver I expect there might even be others. | ||
| The Following User Says Thank You to ditdahdahdah For This Useful Post: | divibi (13-03-2009) |
| | #3 | |||
uplink and downlink absorption due to humidity cloud cover rain accuracy of alignment insertion losses for distribution system also for wall plate terminator dish/lnb tuning as well as all previously posted all in all impossible to quantify and constantly varying | |||
| The Following User Says Thank You to Topper For This Useful Post: | divibi (13-03-2009) |
My System: 90cm Fortec star offset dish. Fortec star motor. Fortec star 0.2 FCKUVN LNB. Technomate 6900 Super Manhatten Plaza ST550 Reciever | Oh well sounded like a good idea when started the thread but I guess you guys are right, there are just too many variables | ||
| | #5 | ||
| Specialist Contributor Join Date: 09-09-2008 Location: Republic of Georgia
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | But some formula may be developed, to allow calculation of some Q mark from these variables. | ||
| | #6 | ||
My System: motorised dish and technomate receiver | I would imagine that the proffessionals have long and intricate forulae, taking into account many variables. But would we know how to work them out, or even have the means or equipment to carry out anty measurements? dddd | ||
| | #7 | |||
| Specialist Contributor Join Date: 11-09-2008 Location: 38.5ºN, 0.5ºW
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | As for signal levels (depends on the receiver) you need -40dBm signal and 8dB C/N or better for a signal to be reliably watchable on an average receiver. | |||
| | #8 | ||
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | The only one partially reliable comparative value that can be roughly estimated by looking at receiver Q% is FEC/SR combination. Since most DTH systems use high SR (22000 to 27500 typical), things can be more easier, and only FEC should be noted. By my personal observations on various sats and receivers, I can roughly estimate, that 1X of Q on satellite with FEC 3/4, equals to 2X quality on satellite with FEC 7/8. Also it should be noted that receiver has AGC, so it may try to "compensate" at certain point the level of signal, and won't reflect it on Q reading. If above text is too complex, here's shorter explanation: Use your receiver on various sats, remember Q and signal on all of them, after some time, you'll develop own sense and skill to know, which Q% of signal is good for trouble-free tv on your receiver and which is not. | ||
| | #9 | ||
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | BombedOne, that's interesting information but it's not going to tell you if you are accurately on the arc. The only way to know for sure it to pick 3 satellites (one east, one south and one west). Then set the dish up on an az/el mount. Choose one transponder on each sat. Point the dish at it and take a note of the signal and quality. Now set up your motor. If you are on the arc you will get the same reading on each satellite with the motor as you did with the az/el mount. | ||
| quality, ratios, satellites |
