BBC Prime move from Hotbird to Eurobird
Old 19-03-2009   #1
My System: Atom 9000 digital multi satellite Win XP
I need some help please.
Have been trying to re-position my Atom 9000 satellite, the details are - Eurobird 9 @ 9E, frequency 11996, symbol rate 27500, FEC 3/4, polarization vertical, modulation QPSK.
Via the usals antenna positioning I set my latitude to 37.02, longitude to 25.15, and then moved the dish to 9 degrees E with all the details (apart from modulation which I could not find) to the above.
Then, after thinking what an ace I was as I've never done this before, tried a channel search to find BBC Prime. Nothing at all!!
Can anyone give me any clues as to where I am going wrong?
nuska is offline   Reply With Quote
Old 19-03-2009   #2
Site administrator
Analoguesat's Avatar
Starting with the lnb aligned onto 13E, wou will need to move the dish alignment about the width of thelnb head to the left as you are facing the dish. Raise the dish a fraction ( a couple of mm will be fine)
You cant miss Eurobird 9A - shes chucking out a huge amount of power. You want the channels listed here:
_http://www.flysat.com/ebird9a.php
Analogue forever!
Analoguesat is online now   Reply With Quote
The Following User Says Thank You to Analoguesat For This Useful Post:
divibi (20-03-2009)
Old 19-03-2009   #3
Thanks for your answer, but I'm afraid I don't understand. I am not physically moving the dish as it's on the roof, just using the remote controller for the Atom box.
Could you explain in very simple terms please as I'm new to all this.
Old 19-03-2009   #4
Amo Amas Amant Admin
Topper's Avatar
Well
In simple terms unless you have a motorised dish your dish will only receive signals from one satellite, to receive a different satellite you must rotate the dish as described
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
The Following User Says Thank You to Topper For This Useful Post:
divibi (20-03-2009)
Old 19-03-2009   #5
Site administrator
Your dish is aligned onto Hotbird 13E. You need to pick up Eurobird 9A at the adjacent orbital slot.
You can either physically slew the dish from 13E to 9E, or fit a dual head "monobloc" lnb on the dish which will give you both 13E and 9E.
Analogue forever!
divibi (20-03-2009)
Old 20-03-2009   #6
As I'm having no luck with this problem I've decided to call in an engineer to align the dish for me. It is motorised but I'm still not able to receive Eurobird at 9E, which is the only one I want.
Thanks for trying to help.
Old 01-04-2009   #7
Update on the previous situation...I found out that the dish was not in fact motorised. The engineer installed a new 1 metre dish and has positioned it to receive Eurobird 9. All fine with loads of mainly useless channels, but absolutely nothing on the frequency of 11996 for Beeb.
Any clues anyone please?
Having paid over £200 for nothing I am not amused.
Old 01-04-2009   #8
Site administrator
Can you see B4U Movies ME which is a free channel on 11996H?
Analogue forever!
Old 01-04-2009   #9
No, although it did appear on frequency 12476, with 'no or bad signal'.
I found Prime on 11488 but it asks for a password which I've never needed before.
Old 01-04-2009   #10
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4
What, you paid him before it worked? Also you shouldn't need a 1 metre dish for that satellite. A 60cm should work fine.
Huevos is online now   Reply With Quote
Old 01-04-2009   #11
Site administrator
Get him back and get him to fix it properly.
Analogue forever!
Old 01-04-2009   #12
Topper's Avatar
Well
It looks like you chose a right
BBC Prime move from Hotbird to Eurobird-cowboy-jpg
Show Your Support
Thank you.
bbc, eurobird, hotbird, prime
[IMG] code is Off
