Are 22khz switches and universal LNBs compatible?
Old 10-04-2009   #1
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4
Are 22khz switches and universal LNBs compatible? If not what does one do when setting up more than 8 LNBs.
Huevos is offline   Reply With Quote
Old 10-04-2009   #2
Mod and septic resident
Channel Hopper's Avatar
Use cascading DiSEqC switches and a compatible receiver.
Channel Hopper is online now   Reply With Quote
Old 11-04-2009   #3
BombedOne's Avatar
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc.
I have two universal LNBs connected via 22khz switch to 1 input of diseqc - works fine.
BombedOne is offline   Reply With Quote
Old 11-04-2009   #4
patmos's Avatar
My System: 1.2 m Eurostar dish KU band W3A, 3.1 M mesh C band on the arc from Atlantic bird3 to Measat 3, 1.5 m offset on PAS 10 KU, 70cm Offset on Eutelsat W2, 2.4m prime (Dual LNB) on PAS 7/10 @ 68 Deg E and Thaicom @ 78 Deg E STARTRACK NC707 Plus, Skyst
I have six LNB and I rather used a 0/12v switch. I was taught that Universal LNBs used 22KHz tone for band switching( Low/High) so it cannot be used with universals.
patmos is offline   Reply With Quote
Old 11-04-2009   #5
BombedOne's Avatar
Yes, but certain satellites broadcast only in one band and one polarisation. For example, I've used to connect 80E and 75E via that switch.
Old 11-04-2009   #6
Won't help the o/p then, so why post it ?
Old 23-04-2009   #7
My System: ?
In this case you need a relay unit for 2 LNBs and one receiver. The existence or not of 22KHz is used in order to selext LNB (east/west).
you do as Channel Hoper says.
You use DiSEqC switches 1.0 with four inputs. These switches are connected to the LNBs. The outputs of these switches are connected to another DiSEqC switch (not 1.0, i think 1.1 or 1.2). The output of the final switch should be led to the receiver.
The receiver should support DiSEqC. You can connect up to 64 LNBs to a single receiver.
tesla is offline   Reply With Quote
22khz, compatible, lnbs, switches, universal
[IMG] code is Off
